h22a1 vs. h22a4
Old Sep 17, 2004 | 10:14 AM
JDM00SI's Avatar
Default h22a1 vs. h22a4
sup,
i'm looking to buy a prelude soon, and wondering does hte 5th gen have a h22a1 or h22 a4?
What are the differences?
Do the 4th gen VTEC have h22a1 or h22a4?
Are there any other types of h22s?
Thanks
Old Sep 17, 2004 | 10:22 AM
JDM00SI's Avatar
Default Re: h22a1 vs. h22a4 (bigbeasta4)
bump
Old Sep 17, 2004 | 10:24 AM
Speedra500's Avatar
the 5th gen comes with the search
AndyD's Avatar
A4 is the ODBII motor. The 96 A1 is OBDII too. 93-95 A1 is ODBI
A1 has 190hp (10:1 comp psitons)
A4 has 195hp. I think the later A4's had 200 in the Type SH
Old Sep 17, 2004 | 10:35 AM
JDM00SI's Avatar
Default Re: h22a1 vs. h22a4 (AndyD)
i kind of don't get the idea of obd1 and obd2..i read about it something concerning the exhaust and ecu...can u explain it pleasE? thanks nooby by the way
Old Sep 17, 2004 | 10:40 AM
98TypeSH's Avatar
OBD II is the implementation of new equipment to help reduce the amount of "bad stuff" a combustion engine produces and puts into the atmosphere. For fear of the greenhouse effect and global warming caused by "smog", this is now standard on all new vehicles in the united states after 1996.
Old Sep 17, 2004 | 10:47 AM
JDM00SI's Avatar
Default Re: h22a1 vs. h22a4 (98TypeSH)
i know that....although i hear of people degrading to obd1 for a certain turbo to work or something in that range. What are some reasons to degrade to obd1? Thanks
Old Sep 17, 2004 | 10:49 AM
98TypeSH's Avatar
Because when you start adding more air flow and more fuel and so on and so forth, the ECU in OBD II is going to think that there is a malfunction and throw the car into limp mode from being to rich/lean or whatever. By switching to OBD 1, you can use a piggy back type tuning program to change all your maps, and have as much air/fuel and flow as you want, without the ECU freaking and throwing a code or putting the car into limp mode.
Yes with engine work you in all probability wont pass smog.
Yes with an OBD1 ECU in an OBD II Chassis they will fail you.
Yes if you do not pass the visual part of the inspection you will fail.
Most places will plug a hand held diagnostic type device into your car to be sure all your emissions equipment is working properly.
What is your goal for your setup? turbo? all motor? stock? Auto-X ?
Its not so much downgrading, the OBD-I ECU's are just less complex, less things to have to worry about when running Hondata, or any other type of engine management with the exception of a VAFC ( doesnt really count as management)
Old Sep 17, 2004 | 10:59 AM
JDM00SI's Avatar
My plans are to have a street car that can be reliable and fast. I'm 16....I've been working for 1.5 Years in fast food to buy a 5th Gen Prelude, and hopefully november i will find one. Being a full time student and part time employee i want to keep as much reliablity as i can. Although i would donate some for performance. My budget is 8500 for a 5th gen Prelude, anyways my goals are performance. I'm not sure if i am going to go turbo because of my little knowledge with cars. Although i've been learning off helpful forums and good members like you. Two months ago i had no clue wat VTEC was...so i keep trying to get more knowledge. My plans for the Prelude when i get it in November is first putting some bolt on mods such as apexi n1 exhaust, dc sports header, etc....
can a obd2 ecu work with a ob1 sensor?
thanks
Old Sep 17, 2004 | 11:02 AM
JDM00SI's Avatar
one of the reasons i am learning is so i won't fix up the car wrong.
ex. many high school students here put a fartcan muffler and a plastic looking spoiler **** on a civic dx or something, HAHA.
Old Sep 17, 2004 | 11:05 AM
JDM00SI's Avatar
i've been going on autotrader each day and searching for 5spd Preludes, in the area, as of now i have 6300 saved. I'm working 31 hour weeks at Sonic...so hopefully by November i will have the funds saved.
Old Sep 17, 2004 | 12:00 PM
98TypeSH's Avatar
you dont need to change over to OBD 1 to use boltons.
although i would suggest getting a better header, or doing the collector mod, as the DC hardly flows better than stock. Look into a GReddy header, should be able to find one for pretty cheap.
The ECU will compensate for your boltons, you only really need tuning with mods that DRASTICLY change the flow and dynamics of the motor. (a high quality header or headwork changes the flow)
I would also suggest some type of suspension work as it does make a world of difference. You should be able to find everything you need in the classifieds on this forum/website. Remeber to take your time, and research your decisions before diving head first into the unknown.
when all else fails, hit the search button. If you cant find your answer there, make a thread and we will be glad to help you.
Old Sep 17, 2004 | 12:38 PM
bad-monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbeasta4 &raquo;</TD></TR><TR><TD CLASS="quote">one of the reasons i am learning is so i won't fix up the car wrong.
ex. many high school students here put a fartcan muffler and a plastic looking spoiler **** on a civic dx or something, HAHA.</TD></TR></TABLE>
this is a good attitude. honestly, you can learn so much from these forums and these people. i knew very little about cars when i first started out reading forums liek this a couple of years ago, and now i feel very confident in my knowledge of my car and others.
a good place for basics is: howstuffworks.com, for the basics on trannies and engines. the big FAQ type threads in this forum, and by just observing here for a while.
Old Sep 17, 2004 | 01:50 PM
ralpheezy's Avatar
Default Re: h22a1 vs. h22a4 (bad-monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">this is a good attitude. honestly, you can learn so much from these forums and these people. i knew very little about cars when i first started out reading forums liek this a couple of years ago, and now i feel very confident in my knowledge of my car and others.</TD></TR></TABLE>
yup i love this place. the info is the best you could ever find. all you got to do is search and if you can't find anything just ask. these guys are friendly too.
Old Sep 17, 2004 | 07:30 PM
matix's Avatar
Default Re: h22a1 vs. h22a4 (ralpheyizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ralpheyizzle &raquo;</TD></TR><TR><TD CLASS="quote">yup i love this place. the info is the best you could ever find. all you got to do is search and if you can't find anything just ask. these guys are friendly too. </TD></TR></TABLE>
TDogg Teg
Nov 19, 2007 12:36 PM
phateless
Nov 21, 2005 06:57 AM
tanjulio
Apr 15, 2003 05:00 PM
ArchAngel Sabastian
Apr 25, 2002 06:42 AM
