92 civic dx wont start
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nacho »</TD></TR><TR><TD CLASS="quote">my car did this forever and i couldnt figure it out. turns out my ECU was fried. worth a shot?</TD></TR></TABLE>
That happened to me too.
Did you check all your fuses kris543? Check grounds?
From: FR Mobbin up on 1 n left hand shiftin n da FF in, killa so cal again, US
check the cap and rotor, plugs. it's possible that the distributor cap and rotor need to be replaced. if that's not the problem, check the firing order. if not, then it's possible that the timing jumped. one other thing it may also be is one of the components in the distributor itself might be bad.
car was wrecked and the car still ran. i got it from the junk yard as just a shell to put my motor into. the junk yard said t hey drove the car around and it was running fine. It was hit from the front. Still could be ECU?
i would check the things that i listed. the only time i fried an ecu was when i wired something wrong.
Sounds like a fuel issue then.
When I had a problem like this, with the car starting but dying immediately, my main relay and pump were fine, the fuel filter was new, but the injectors weren't firing correctly because of my ECU.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kris543 »</TD></TR><TR><TD CLASS="quote">What are the odds of both ECU's being bad.</TD></TR></TABLE>
Pretty slim.
I'm not saying that it's the ECU for sure, but that's just what my problem was.
Pretty slim.
projectej8
Sep 2, 2005 10:04 PM
