Help With the P1739 DTC
Old Sep 17, 2004 | 10:01 AM
espiritu's Avatar
Default Help With the P1739 DTC
I have a P1739 showing in the scanner and the code saids Automatic Transaxle, can someone be more specific if they had or hear someone with the same code. Also do you guys think is because my Drive Axle needs to be replaced that migth be thecause of the problem?
Old Sep 17, 2004 | 10:26 AM
Turbowa's Avatar
Default Re: Help With the P1739 DTC (espiritu)
Its the code for the 3rd Clutch pressure switch. Check the switch with a multimeter to see if it has more then 10 ohms resistance. If it does NOT replace the switch. It is located on the front of the tranny all the way down at the bottom front. Its on the corner facing the block.
Tyler Cloutier
Sep 7, 2024 05:13 PM
joshua89
Jul 30, 2011 01:36 PM
rjp
Mar 16, 2010 08:07 PM
allmotor2.1
Nov 17, 2007 05:01 AM
PnkRokCountryboy
Sep 2, 2007 01:06 PM
