Integra RPM signal?
There should be an RPM signal connection point in the upper right corner of the engine bay, right near the brake master cylinder and the driver's-side hood hinge.
i knw that inside the distributor, a blue/white wire is connected to the coil. that wire is the rpm wire. you can get to this wire from outside the distributor by the bunch of wires coming out of it. but im not sure if the color is a blue/white one. i havent really checked. but im 100% sure its the blue/white wire thats attached to the coil
