found out why my clutch wont engage. dont know how to fix it.
Old Sep 16, 2004 | 10:57 PM
JDMorgan's Avatar
Default found out why my clutch wont engage. dont know how to fix it.
hey i just threw a quick swap together for my 90 integra(RS) obd0 b18c1 with an ls s1 tranny, i got an oem replacement clutch with new pp and bearings along with an 8lb flywheel. well i put it all together and it went up first try with only 1 person helping since it makes it a little easier. well guess what my throw out bearing doesnt hit my pp untill VERY close to the top. i was told by 3 people it wasnt enough to engage the clutch all the way. well this got me thinkin.....hey i should turn the flywheel.....too bad i got an 8 lb'er. i could go take my stock flywheel to the local shop and have it turned ALOT. this flywheel has burn marks in it so i am hesitant to.
so which should i do test my luck with the setup i baught, or use a stock one thats been turned untill my clutch is worn in?
Old Sep 17, 2004 | 02:55 AM
Sliced Beard's Avatar
Default Re: found out why my clutch wont engage. dont know how to fix it. (KraZEtEggIE)
you might have a bent clutch release arm
Old Sep 17, 2004 | 04:14 PM
psychotic_z's Avatar
Default Re: found out why my clutch wont engage. dont know how to fix it. (DirtySol)
Cable clutch? Adjust the cable.
KillerHippy
10
Sep 27, 2010 11:26 AM
dk4ever
Oct 17, 2008 05:11 AM
chrisb
Sep 7, 2004 12:55 AM
danny98r
Jun 24, 2004 12:15 PM
89 CRX SI
Sep 25, 2002 07:04 AM
