Need Help on Removing Air Bag
Old Dec 9, 2001 | 09:26 PM
PrjctDC2-R's Avatar
New User
Default Need Help on Removing Air Bag
Did a search, couldnt find anything.
I havent checked out the wheel yet... But what should i be looking for to disable and remove the Drivers side Airbag (to prepare installation of Aftermarket steering wheel).. Is it a difficult job?.. any special tools needed? Thanks in Advance to anyone who can give me some info
Old Dec 9, 2001 | 09:27 PM
ITR#132's Avatar
Default Re: Need Help on Removing Air Bag (PrjctDC2-R)
you will need the special torx screwdriver to unscrew the airbag.
Old Dec 9, 2001 | 09:29 PM
RagingAngel's Avatar
You'll need some torx screwdriver attachments so you can remove the airbag from the side of the wheel (two access panels)....
they recommend that you unplug the battery and wait up to 5mins for the residual charge to die....
make sure you are static free since that is enough to set off the bag...(all according to the book)
You'll need a 19mm socket.... and that is about it to remove the whole mess.... there are a few clips and all but it is pretty much self-explanatory once you get there....
Old Dec 9, 2001 | 09:31 PM
Default Re: Need Help on Removing Air Bag (RagingAngel)
DAMMIT....2 minutes too late....!
Old Dec 9, 2001 | 09:45 PM
PrjctDC2-R's Avatar
New User
Thanks guys
Uno Momento Por Favor... I have one more question... whats the best way to disable the SRS light? im assuming once you remove the airbag the SRS light will come on?
[Modified by PrjctDC2-R, 11:30 PM 12/9/2001]
Old Dec 9, 2001 | 10:51 PM
Unlimited's Avatar
New User
take out srs fuse under the dash
take out srs light in the cluster
jdmpassword562
11
Mar 24, 2007 11:34 PM
vti444
18
Aug 26, 2004 11:18 AM
Fobstylez
Sep 12, 2003 09:24 AM
UndergroundVR-4
Mar 22, 2003 09:57 AM
the big ragu
Jun 9, 2002 12:01 PM
