another OBD0 to OBD1 thread, please help!!
Old Sep 16, 2004 | 10:11 PM
Loccster's Avatar
Default another OBD0 to OBD1 thread, please help!!
ok guys, im stuck in a situation where i desperately need some help...
I have a 0bd0 b16a1 currently in my EF, and im thinking about converting it to obd1 just to make it legal in CA. I've read the article on g2ic.com, great article but i still have some questions.
==taken from the article==
Required Parts:
-obd0 to obd1 conversion harness
-obd1 distributor (make sure its one that fits your engine)
-obd1 ecu (make sure its one that will work with your engine)
-4 wire heated O2 sensor (preferably one with Honda connectors)
-obd0 engine harness
here's what im concerning about:
1. do i need a obd1 header since the obd0 b16 header comes with 2 o2 sensors? or is there a way to bypass that?
2. do i really need obd1 intake manifold & TB since the obd0 TB doesnt have a map sensor and obd1 requires one? and the obd0 IM has all kinds of vacumm hoses on it.
im trying to keep the EF alive, so please help a fellow HT member out...thanks!!!
Old Sep 16, 2004 | 10:38 PM
eda6's Avatar
Default Re: another OBD0 to OBD1 thread, please help!! (Loccster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loccster &raquo;</TD></TR><TR><TD CLASS="quote">
2. do i really need obd1 intake manifold & TB since the obd0 TB doesnt have a map sensor and obd1 requires one? and the obd0 IM has all kinds of vacumm hoses on it.</TD></TR></TABLE>
1. Plug the hole.
2. No. I have an obd2 manifold. If you decide to get and obd 1/2 manifold you just reroute the vac lines as follows fpr to im, pcv to im, brake booster to im, and tb to map sensor on the firewall.
I'm planning to do this soon.
Old Sep 16, 2004 | 10:50 PM
Loccster's Avatar
Default Re: another OBD0 to OBD1 thread, please help!! (eda6 hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 hb &raquo;</TD></TR><TR><TD CLASS="quote">
1. Plug the hole.
I'm planning to do this soon. </TD></TR></TABLE>
so the obd1 ecu will not throw any codes even if i dont have a map sensor?
thanks for helping me out eda6 hb
Old Sep 17, 2004 | 07:21 AM
eda6's Avatar
You have a map sensor on the firewall. Connect vacuum hose from tb to map sensor.
Old Sep 17, 2004 | 04:09 PM
Loccster's Avatar
cool, i got what i needed to know. Thanks alot guys!
jdmboi3278
Engine Management and Tuning
Jan 28, 2009 11:17 PM
MniMeHatch89
May 24, 2007 09:10 PM
skud_dusty
13
Apr 25, 2003 11:51 PM
EFing8
11
Dec 15, 2002 09:08 AM
h46it
Jun 18, 2002 05:23 PM
