lower control arms
Old Sep 16, 2004 | 05:07 PM
91EFHatch's Avatar
Default Front lower control arms
are there even after market front lower control arms for the ef? i know they make then for the 92-95? i searched and didnt fine anything only about the rear lcas..
Old Sep 16, 2004 | 05:18 PM
EL Vap133's Avatar
Default Re: Front lower control arms (91EFHatch)
I haven't heard of any, but there might be.
Old Sep 16, 2004 | 05:26 PM
LAMA's Avatar
Default Re: Front lower control arms (EL Vap133)
ive seen someone post a pic of ones on here, not sure if they were the 92-95 ones, but they were blue I think, its been a while.
Old Sep 16, 2004 | 06:01 PM
dr_latino999's Avatar
Default Re: Front lower control arms (LAMA)
****!! I've seen them before, there was a big discussion on them because they were on Ebay and all but it turned out the company was reputable. Good luck searching.
Old Sep 17, 2004 | 12:50 PM
91EFHatch's Avatar
anyone else?
Old Sep 17, 2004 | 01:41 PM
90civichbsi's Avatar
Function 7 makes some (ebay type)
SPC (Specialty Products Company) makes some that are 1/2 shorter than stock to correct camber and allow for a wider rear tire
if im not mistaked the SRR ones for EG's will work but dont quote me on that
Old Sep 17, 2004 | 02:01 PM
spaceman's Avatar
we need to get some people to make some good stuff like this for our cars..i asked skank2 to make camber kits for crx and they said no..than one day they said maybe..does function7 have a website or srr?
Old Sep 17, 2004 | 02:14 PM
JoshDM's Avatar
Default Re: Front lower control arms (spaceman)
honda part#'s
51355-sh3-020 right
51365-sh3-020 left
dealer list is $154.92
Old Sep 17, 2004 | 02:19 PM
91EFHatch's Avatar
Default Re: Front lower control arms (JoshDM)
ok i guess people dont read....FRONT LCAs not rear.......and no not stock
Old Sep 17, 2004 | 02:21 PM
91EFHatch's Avatar
Default Re: Front lower control arms (90civichbsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civichbsi &raquo;</TD></TR><TR><TD CLASS="quote">
if im not mistaked the SRR ones for EG's will work but dont quote me on that</TD></TR></TABLE>
yes the SRR rear lca from the 92-95 fit on the ef.....bling bling,but im looking for aftermarket for the front to beef it up
Old Sep 17, 2004 | 02:42 PM
realfasthonda's Avatar
i have srr eg lca's on my civic
heres some pics
top- 91 civic si lca
middle- 90-93 integra lca
bottom- 92-95 civic lca
things to notice: 2nd gen integra's lca's have a different placement for the shock.
the eg lca's that i got have a different place for the rear sway bar to bolt on to i actually had to moddify my sway bar brakets and by some bolts and nuts to make it work.
Old Sep 17, 2004 | 02:45 PM
Default Re: Front lower control arms (realfasthonda)
ok nvm i thought you ment rear i just wasted all my time
Old Sep 17, 2004 | 02:48 PM
APEX CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91EFHatch &raquo;</TD></TR><TR><TD CLASS="quote">ok i guess people dont read....FRONT LCAs not rear.......and no not stock </TD></TR></TABLE>
ha ha reading owns joo...
Old Sep 17, 2004 | 05:06 PM
krazie1's Avatar
BANNED
Default Re: Front lower control arms (APEX CRX)
fellow peeps
lets try to READ THE POST!!! before replying or assuming
Old Sep 17, 2004 | 05:15 PM
JOEY F.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by realfasthonda &raquo;</TD></TR><TR><TD CLASS="quote">
I know this thread was for the front LCAs but this kinda bothers me....
Doesnt the SRR arm look a bit longer from the top LCA? (civic LCA)
This would effect suspension alignment correct?
Old Sep 17, 2004 | 09:04 PM
Default Re: Front lower control arms (JOEY F.)
from the picture it looks that way but they are infact the same lenth
Old Sep 17, 2004 | 09:29 PM
B16 CRX's Avatar
Those are sick where did you buy them from? and how much?
Old Sep 17, 2004 | 10:37 PM
GSRCRXsi's Avatar
Default Re: Front lower control arms (B16 CRX)
and how would you mount a sway bar with those rear arms?
Old Sep 18, 2004 | 01:47 PM
ordered them from one of the sponsers of this site cant remember from who though. they were like $180
mounted my sway bar with some modification the bolt goes through the hole on the lca. used some washers and a nut
Old Sep 18, 2004 | 01:52 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
i already have a DB rear trailing arm converion for disk brakes, i guess i'll be looking into some RLCA's..
thumper64
Suspension & Brakes
Nov 10, 2009 07:13 AM
Madskillzracer
Jan 2, 2008 04:04 PM
matt1982
Mar 17, 2007 09:45 AM
noakEK4
Sep 16, 2006 05:16 PM
DaCRXboi
Jul 23, 2006 11:36 PM
