Just did a b18c1 into a vx questions on clutch?????and linkage
Old Sep 16, 2004 | 04:44 PM
93FastLs's Avatar
Default Just did a b18c1 into a vx questions on clutch?????and linkage
i just put a 6puck act clutch into my gsr, now i took the clutch mast cylinder off cause i was gonna use the gsr one, but it didnt work right.. so i went back to the old vx one i bled it, took it for a spin and the pedal feels kinda stiff but not too much, it's got a lot of play, but then after like a couple of miles there is no play. is the old master cyl. bad as well ? then theres time im at a light, shift into neutral and then my car shuts off. or it wont go into gear <~! is that a shift linkage problem or is that still with the clutch? sorry for the bad grammer and all that ish! im just asken questions
Old Sep 16, 2004 | 04:46 PM
slambedcivic's Avatar
Default Re: Just did a b18c1 into a vx questions on clutch?????and linkage (93FastLs)
if the old master cyliner is bad, youll usually lose all pedal pressure. slave cylinder could be a possibility. and was your throw out bearing replaced as well?
Old Sep 16, 2004 | 04:51 PM
chad's Avatar
Moderator
rebleed the clutch line....you probably have some air in there....
slave cylinder is same for bseries and d series!!!
Ryank327
Transmission & Drivetrain
13
Jul 31, 2014 01:19 PM
ckinne
Apr 1, 2009 09:53 AM
ludewithanh22
Jul 9, 2005 07:47 PM
bambbrose
Jul 6, 2005 12:46 PM
del_parker
Sep 1, 2003 07:17 PM
