00 Civic Suspension Question!
Old Sep 16, 2004 | 04:10 PM
jackal99a's Avatar
Default 00 Civic Suspension Question!
I just purchased my 1st Honda, 2000 civic EX, 34K miles, took it to Honda and they checked it out, gave it 2 thumbs up....but today I noticed that the driver side rear sits .5" lower then the passenger side rear...is this normal? if so how does one fix this without cutting springs?
Old Sep 16, 2004 | 04:52 PM
chad's Avatar
Moderator
Default Re: 00 Civic Suspension Question! (jackal99a)
not normal.....
where'd you buy it?
possible that the spring came unseated in the perch.....
or a really really really fat person drove the car....
Old Sep 17, 2004 | 08:41 AM
Naturally Aspirated's Avatar
right before u measured ur car, did u sit on ur driver side with no one on passenger side?
cos ur weight depresses the shock and it takes around 1-2 minutes to level back with no weight height...
Old Sep 17, 2004 | 10:12 AM
jdm123's Avatar
Default Re: 00 Civic Suspension Question! (Naturally Aspirated)
blown shock maybe
Old Sep 17, 2004 | 10:55 AM
Marauder's Avatar
Default Re: 00 Civic Suspension Question! (jdm123)
Its normal!
Honda had a technical service bulletin on it and said that its normal.
If you get a set of coilovers, you can level it out though.
Old Sep 17, 2004 | 11:02 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jackal99a &raquo;</TD></TR><TR><TD CLASS="quote">I just purchased my 1st Honda, 2000 civic EX, 34K miles, took it to Honda and they checked it out, gave it 2 thumbs up....but today I noticed that the driver side rear sits .5" lower then the passenger side rear...is this normal? if so how does one fix this without cutting springs?</TD></TR></TABLE>
This is perfectly normal. I freaked out after installing my springs (eibach) because the driver was lower than the pass. I asked a bunch of questions on H-T, google, Clubsi. Nobody had a straight answer, but most said it was normal.
I switched the sides the shocks were on (from left to right, and vise versa), and even re-installed the stock springs and switched from side to side. I found that all four springs that I had installed on the left side of the car sat lower than the right (although, it was barely noticeable with the stockers, which is probably why I never noticed it until I upgraded). Irrefutable evidence that the weigth distribution of the car makes the drivers side sit lower.
The only way to 'fix' the problem would be to install coilovers, and dial in the exact gap you want all around.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm123 &raquo;</TD></TR><TR><TD CLASS="quote">blown shock maybe</TD></TR></TABLE>
Shocks don't set the ride height of the car, springs do.
swiftcrezzer
Suspension & Brakes
Jul 1, 2017 09:09 AM
bduncan
Honda Civic (2001 - 2005)
May 19, 2008 10:27 AM
SWC
Suspension & Brakes
Jun 9, 2006 04:06 AM
hooddub
May 20, 2006 03:31 AM
xjohnx
Jul 22, 2002 09:11 AM
