bent valves?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">Bent valves would throw codes 71 to 74 for cylinder misfires. Is the VTEC solenoid engaging? (This could cause the rev limit.)</TD></TR></TABLE>
were gunna go pull the codes today and we'll see, but it sounds like vtec is engaging how is another way you can tell?
A simple compression check will tell you if you have bent or improperly adjusted valves.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb6h22 »</TD></TR><TR><TD CLASS="quote">
were gunna go pull the codes today and we'll see, but it sounds like vtec is engaging how is another way you can tell?</TD></TR></TABLE>
Most people mistake the intake air bypass (IAB) switch at 5700 rpm for the VTEC engagement on a GSR. However, the VTEC crossover occurs near 4400 rpm and is usually inaudible and imperceptible (as it should always be if it is tuned properly) on a stock motor. How does the motor pull and sound as it approaches this 6900 rpm limit?
well we pulled the code, and it was only the secondary o2 sensor. that shouldnt keep it from revving passed 6800/6900...
dogginator, the motor pulls hard and strong as it approaches 6900rpm's
What happens when it hits 6900 RPM? Does it cut-out like a rev limiter or just quit producing enough power to accelerate the motor? It has to do one or the other.
Also, does this limit happen the same for all gears?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">What happens when it hits 6900 RPM? Does it cut-out like a rev limiter or just quit producing enough power to accelerate the motor? It has to do one or the other.
Also, does this limit happen the same for all gears?</TD></TR></TABLE>
it cut's-out like a rev limiter. and yes it does this in 1st and 2nd im pretty sure its the same for every gear
Also, does this limit happen the same for all gears?</TD></TR></TABLE>it cut's-out like a rev limiter. and yes it does this in 1st and 2nd im pretty sure its the same for every gear
Did you do any wiring changes like put in a Vtec controler or something like that???? I ran in to it with my car. I had something wired wrong or backwards and it would only run that high before cutting out. Also try diconnecting the battery for 30 to 50 sec. and connect it again. Try that if check engine light is off and still runs that way then I'm not sure at this point but try that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ttercahnncoe »</TD></TR><TR><TD CLASS="quote">Did you do any wiring changes like put in a Vtec controler or something like that???? I ran in to it with my car. I had something wired wrong or backwards and it would only run that high before cutting out. Also try diconnecting the battery for 30 to 50 sec. and connect it again. Try that if check engine light is off and still runs that way then I'm not sure at this point but try that</TD></TR></TABLE>
yeah i used to have a vafc maybe i should check the wires on the ecu. but yeah i tried resetting the ecu and im still getting the CEL
Your ECU may be in a limp mode. But I'm thinking the limp mode limited the rpm to around 4000. Have you verified that the ECU is a P72? The P/N is printed where the wiring harness connects. It should read 37820-P72-A0#.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">Is an aftermarket ignition with a rev limiter installed on this car?</TD></TR></TABLE>
no its the stock p72 ecu
we still cant figure out whats going on
lemongreenhatch
Oct 27, 2004 09:28 PM
spoon23_JDizM AkA SpOoN20
Sep 9, 2004 06:04 AM
