Oil pan gasket....help
Old Sep 16, 2004 | 11:24 AM
Black Raven
Guest
Posts: n/a
Default Oil pan gasket....help
i took my car to the shop this morning becuz oil started to leak. Found out that the oil filter had a crack and i got that replace and now it doesn't leak anymore. But the shop told me to repalce the gasket on the oil pan since oil got all over it. They said they would charge $150 for labor to to replace the gasket on the oil pan. Do u guys think that's a rip off? Also how hard is it to replace the gasket by myself? Also do u guys think it is neccesary to chage the oil pan gasket?
Old Sep 16, 2004 | 11:36 AM
00siALLmotor's Avatar
Default Re: Oil pan gasket....help (AiKwuJiTong)
I would replace it... $150 sounds reasonable... What shop is this that you are taking your car to? You can do it by yourself, might take some time though (gotta take off the header, and some other brackets).... If you want, I know a guy that will change it for u for about $150, plus he uses genuine honda parts... Anyhow, good luck....
Old Sep 16, 2004 | 11:57 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AiKwuJiTong &raquo;</TD></TR><TR><TD CLASS="quote">... But the shop told me to repalce the gasket on the oil pan since oil got all over it...</TD></TR></TABLE>So basically the shop is saying that the pan gasket is made out of some kind of rubber that can't tolerate getting oil on it? (Think about that...)
Old Sep 16, 2004 | 12:12 PM
Redtail's Avatar
Default Re: Oil pan gasket....help (JimBlake)
Yeah, I think they are trying to rip you...
Old Sep 16, 2004 | 12:24 PM
AbaZ's Avatar
Default Re: Oil pan gasket....help (Redtail)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redtail &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, I think they are trying to rip you...</TD></TR></TABLE>
Why? going shop rate at is around 60-85 dollars, flat rate shows probably 1.5,
so about 100 bucks in labor, 15 bucks for the gasket, and 15 bucks for oil. Thats pretty close to 150.
Is that a ripoff? no, is it expensive? yes.. I personally would do it yourself. It's very easy.
Jeff
Old Sep 16, 2004 | 12:36 PM
timmy8151's Avatar
Default Re: Oil pan gasket....help (AbaZ)
They're trying to rip him because he doesn't need a new gasket. As posted above, just because oil got all over the pan, doesn't mean he needs a new gasket.
But if you want to change it yourself, it's a fairly easy job.
Black Raven
Guest
Posts: n/a
i don't think im going to ge it replace. Its not worth $150. I mean when i change the oil it gets all over the place anyways, so it wouldn't matter too much.
Old Sep 16, 2004 | 12:55 PM
Mattyg2's Avatar
changing a oil pan gasket is easy but i still have a leak, i need a torque wrench to torque em down to spec's :-(
cletus11
Jan 14, 2012 12:49 PM
george34
Apr 14, 2006 03:37 PM
Mattyg2
Aug 28, 2004 04:50 PM
Rhetoric
Aug 17, 2003 12:34 PM
d0nkeyxPunch
May 10, 2002 04:01 AM
