Electric guages, how to?
Old Sep 16, 2004 | 11:10 AM
PowderB16's Avatar
Default Electric guages, how to?
I just recently bought electric oil pressure and water temperature guages, where is the best spot to put the sender unit on the block?
Old Sep 16, 2004 | 11:20 AM
Archidictus's Avatar
Unceasing Measure
Default Re: Electric guages, how to? (PowderB16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PowderB16 &raquo;</TD></TR><TR><TD CLASS="quote">I just recently bought electric oil pressure and water temperature guages, where is the best spot to put the sender unit on the block?</TD></TR></TABLE>
There should be a pulgged hole for coolant and one for oil right under your distributor. You have to use a hex key to get these plugs out and then you can probably just thread the senders right into the block .
Old Sep 16, 2004 | 11:59 AM
PowderB16's Avatar
Default Re: Electric guages, how to? (Archidictus)
tru, i think i found the one for the oil but im kinda concerned about space, i think it should fit tho, but i still cant find the water temp, could you tell me if it is lower than the oil or to the left or right?
Old Sep 16, 2004 | 12:39 PM
Unceasing Measure
When I installed mine it was on a D16Z6, so I can't say for sure on your B16. Sorry .
Old Sep 16, 2004 | 01:02 PM
Luserkid's Avatar
Dont you just tap it where the thermostat housing is?
Old Sep 16, 2004 | 01:16 PM
-Trinitron-'s Avatar
For the oil pressure, youremove the oil pressure sensor above the oil filter. You will need a BSTP/NPT 1/8" adapter. You will also need a small braided steel hose. You do not want to thread the sender directly into the block because it issupposed to be insulated from vibration. Tee the sender with the OEM oil pressure sensor.
Old Sep 16, 2004 | 01:37 PM
PowderB16's Avatar
Default Re: (-TRINiTRON-)
so i do that even if it is an electrical guage?
91(si)hatchey
Jan 26, 2007 12:58 PM
mr abstract
Jan 23, 2007 02:00 PM
THEUSED
Apr 27, 2005 07:37 AM
Shambo
36
Mar 21, 2005 02:37 PM
rev_it
Oct 25, 2004 03:58 PM
