integra running 13s all motor?
Old Sep 16, 2004 | 10:58 AM
DriveSlowHomie's Avatar
Default integra running 13s all motor?
anyone has a integra with a/c and p/s on running 13s all motor? what setup do you have...
Old Sep 16, 2004 | 11:13 AM
AlxSiR7's Avatar
Default Re: integra running 13s all motor? (cmGSR916)
um.. its possible, i think the lastest issue of honda tuner has a car they have been trying to achieve just that. they finally did.. 13.8 i think, but then blew the motor.. i know it was a b series of some sort. i will check when i get back home.
Old Sep 16, 2004 | 11:16 AM
94whtgsr's Avatar
really isnt hard at all... my friend ran a 14.009@99.8 with a 2.1 60ft with i/h/e/im/tb/clutch flywheel.. the key was he just gutted his car. so easily attainable considering what he had done. it was very impressive
Old Sep 16, 2004 | 11:19 AM
Red CiViC Hatch's Avatar
Default Re: (94whtgsr)
how much do the stock integras weigh?
Old Sep 16, 2004 | 11:30 AM
WeakEK's Avatar
2800?
Old Sep 16, 2004 | 11:36 AM
smemts's Avatar
Default Re: (WeakEK)
Stock Integra's weigh around 2600. That car in Honda tuning was a four door, and it had full interior and everything. It was a B20/vtec setup using all Honda factory parts. And they did it for right around 10,000 (including the cost of the car). It was pretty cool.
Old Sep 16, 2004 | 11:51 AM
iH8RICERZ's Avatar
Default Re: (smemts)
my friend has done it in his 00 gsr= 13.8 (i personally think his car is gifted and he definately knows how to drive his car). Even when he miss shifted, he hit a 14.2.....all the mods that i remember at the time was:
ctr intake cam
itr exhaust cam
cam gears
msd 6al ignition
msd ss blaster coil
msd wires
intake (forgot which kind)
DC 4-1 header
clutch
flywheel
drag radials
open header
car was moderately gutted..just dash, doorpanels, and front driver seat
AC and Powersteering was still active
Old Sep 16, 2004 | 12:45 PM
97TegraLS's Avatar
If your asking the ? here. You an't gunna make it happen.
Old Sep 16, 2004 | 12:55 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: integra running 13s all motor? (97TegraLS)
I think Tony the Tiger's all motor 1995 GS-R still has PS, not sure about A/C. The latest dyno plot on his website shows 215 fwhp, 12.2:1 CR and bored to 1825cc. Currently he's at 2.0L with 14.5:1 CR and 9200 RPM redline not sure of the numbers there.
Old Sep 16, 2004 | 01:25 PM
goforbroke's Avatar
MEAT PATTY
Default Re: integra running 13s all motor? (PatrickGSR94)
Yeah the one everyone is referring to in the magazine ran a 13.6 when it was all said and done and it made 211whp.
I find it funny though because they spun a bearing. It was from the "stock" b20 rod bolts when they stretched. I just think its strange they looked over that when they had a very competitent shop put the motor together. ARP rod bolts would of been nice. I think they were trying to stick to the main ideal of all honda parts.
Old Sep 16, 2004 | 01:44 PM
_silverTEG's Avatar
ive read he dipped into low 12's all motor, and "heard" about 11's?
Old Sep 16, 2004 | 01:52 PM
greaseball's Avatar
13's all day long! 10.5:1 c/r bored to 84mm. full interior, power steering, and a/c.
Old Sep 16, 2004 | 02:28 PM
patdemps's Avatar
Default Re: integra running 13s all motor? (greaseball)
I ran a 14.2 in my only track run with my ITR cams in my GSR. I pulled 190whp on the dyno and it was a very quick car. That was on a slick night where they ended up postponing the event because of the mist, I was getting 2.3's which was fairly good for the conditions. I could have easily pulled mid to high 13's with a tune of the car and a nice track day. That was on street tires too, throw me some drag radials and definately some mid 13 sec. times. My GSR weighed in at 2,440lbs. with full interior. I gutted the ac/ps though....I don't see why that makes a difference in your question. I could have put it back in and done the same thing, it isn't that much of a difference. I just like the feel of the car better without PS. I live in Maine so I don't need AC.
That was on a stock bottom end, stock cam gears, only tuned for vtec crossover, untouched fuel, still stock redline despite having dpr stage 6 headwork and a full valvetrain that could handle 10k shifts, with ITR cams, so I would have been pulling all the way to about 8500-8600 or so before those cams started to die off. My power was still rising rapidly at my 8k redline. I parted the setup months after the race because I wanted turbo. It was a fun *** setup though.....it was an autocross machine.
Old Sep 16, 2004 | 02:37 PM
alfaaay's Avatar
Default Re: integra running 13s all motor? (patdemps)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red CiViC Hatch &raquo;</TD></TR><TR><TD CLASS="quote">how much do the stock integras weigh?</TD></TR></TABLE>
A guaged by a weigh station, mine with a full interior, myself, and less than 20 lbs of extra stuff came out to 2800 lbs. Fatass.
Old Sep 16, 2004 | 03:05 PM
GS-Rdriven's Avatar
Default Re: integra running 13s all motor? (alfaaay)
i'd take a all motor 13 sec. car over a boosted one everyday......
Old Sep 16, 2004 | 04:57 PM
92redgsr's Avatar
b17 block ctr pistons. Pr3 head p/p ctr cams, valvetrain. All the itr bolt ons tb, mani, header. 13.8 untunned full interior only vtec moved up.
Old Sep 16, 2004 | 07:51 PM
streetjdm's Avatar
Default Re: integra running 13s all motor? (92redgsr)
*b17 block ctr pistons. Pr3 head p/p ctr cams, valvetrain. All the itr bolt ons tb, mani, header. 13.8 untunned full interior only vtec moved up.*
what chassis was that on? i want to do b18 block with pr3 head and all ITR internals and skunk im what do u think i will be running?? p73 pistons, decked block, milled head, port matched to ITR??
Old Sep 16, 2004 | 08:59 PM
smemts's Avatar
Default Re: integra running 13s all motor? (streetjdm)
Tony's car =
The videos of that thing that went around were awesome
lo_jack
Aug 26, 2009 06:28 AM
domepeezo1
Aug 16, 2009 02:39 AM
litterbox
Jul 29, 2005 08:48 AM
Death_to_Thieves
12
Oct 15, 2004 10:51 PM
1fstevo
Jun 29, 2004 12:56 PM
