I was told not to change my Spark Plug Wires ?????
Old Sep 16, 2004 | 05:07 AM
d9h's Avatar
d9h
Default I was told not to change my Spark Plug Wires ?????
I was having some work done to my 92 Accord EX the other day and I asked the Certified Honda mechanic what he would charge to change out the spark plug wires. He said that as long as they didn't look worn that they shouldn't be changed. Does this make sense? As far as I can tell, the current wires are stock. I bought the car used so I'm not sure how old they are, thus my reasoning for wanting to put new ones on. Any thoughts?
d9h
Old Sep 16, 2004 | 05:58 AM
93CivicDxer's Avatar
Default Re: I was told not to change my Spark Plug Wires ????? (d9h)
If you feel like they need to be changed, change them
Old Sep 16, 2004 | 06:10 AM
d9h's Avatar
d9h
Default Re: I was told not to change my Spark Plug Wires ????? (AcCoRdInGtO_91)
Does anyone know of a reason why I should not change them? I've never heard of not changing wires.
Old Sep 16, 2004 | 06:46 AM
jweller's Avatar
as long as you use a quality wire, theres no harm to be done by swapping them.
Old Sep 16, 2004 | 07:06 AM
Al Czervik's Avatar
Probably something similar to the old saying if something is not broke then don't fix it. If the wires are not chewed up and are in good shape you should be fine.
Old Sep 16, 2004 | 07:53 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: I was told not to change my Spark Plug Wires ????? (kattiflis)
If you have a multimeter you could test the resistance of the wires and then compare that to the manual. If the resistance doesn't match that of the manual then change them.
Old Sep 16, 2004 | 08:03 AM
TOAB's Avatar
^ that
no point in paying to replace something that aint broke.
Old Sep 16, 2004 | 08:30 AM
JimBlake's Avatar
Default Re: (TOAB)
There's 2 different ways for plug wires to fail. Incorrect resistance, measure that with a multi-meter & compare against what they're supposed to be.
Then their insulation can break down. Even if the resistance is correct. Wait until after dark, & this works better with the engine thoroughly cold. Turn off all the lights & start the engine. Look for arcing around the cap & wires. It'll look like a dull blue glow. Maybe spray water from a windex bottle to make it more visible?? (If the arcing is across the surface of the cap, then replace the cap.)
Old Sep 16, 2004 | 08:58 AM
luckydog's Avatar
Default Re: (JimBlake)
Wow- a conscienstiuos mechanic turning down a half hour of easy work. Where is this guy located?
Old Sep 16, 2004 | 09:15 AM
phoenixitc's Avatar
I've received similar advice from my Honda dealership. I changed my wires after 110k miles only when I noticed a miss when revving hard. I changed the plug wires and the miss stopped. Along with the suggestion of only quality, consider which brand. I've read threads about some brands not having a proper fit. I purchased Accel wires and the cap covers that seal the valve cover "holes" is not as tight as the factory wires. The lengths were perfect, they even fit in the wire guides on the cover. The fit onto the top of the plugs was perfect.
Old Sep 16, 2004 | 10:37 AM
d9h's Avatar
d9h
I appreciate the replies. It doesn't sound like it will do me any harm to change them out. Thanks.
d9h
Old Sep 16, 2004 | 10:51 AM
phoenixitc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d9h &raquo;</TD></TR><TR><TD CLASS="quote">I appreciate the replies. It doesn't sound like it will do me any harm to change them out. Thanks.
d9h</TD></TR></TABLE>
Nope, the most difficult decision really is which color to choose
Old Sep 17, 2004 | 04:04 AM
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Then their insulation can break down. Even if the resistance is correct. Wait until after dark, & this works better with the engine thoroughly cold. Turn off all the lights & start the engine. Look for arcing around the cap & wires. It'll look like a dull blue glow. Maybe spray water from a windex bottle to make it more visible?? (If the arcing is across the surface of the cap, then replace the cap.)
I agree. Yesterday I checked the resistance on my wires and they all checked good. They were 85* F when I checked them as opposed to the 70* F the manual calls out but I don't know how big of a difference that makes. Anyway, even though they checked ok they visually aren't so good. The outside of the wires look to be breaking down (little cracks in the rubber and looking dried out) where they go into the boots. I didn't check for arcing since it was still light out. But I'm going to replace them anyway when I do my timing belt and other things in a few weeks.
Old Sep 17, 2004 | 05:27 AM
JimBlake's Avatar
Default Re: (TouringAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">... (little cracks in the rubber and looking dried out).</TD></TR></TABLE>Yeah, looking for arcing in the dark is one way to find that stuff before it even gets big enough to see...
Resistance changes with temperature, but probably not that much from 70 to 85. If the resistance was borderline, then you'd want to measure it again at the right temperature. Unless you've got a Fluke, the temperature change is probably less than the meter-error. Usually when the resistance fails, it's WAY off.
Old Sep 17, 2004 | 06:05 AM
H-T Order of Merit
no, the resistance on the longest wire was well within spec and just got lower as the wires got shorter.
I'll have to check for arcing tonight if I remember.
Old Sep 17, 2004 | 08:42 AM
Vic Nyce's Avatar
what resistance are we shooting for when testing the wires?
Old Sep 17, 2004 | 09:26 AM
H-T Order of Merit
Default Re: (Vic Nyce)
25,000 Ohms max at 70*F
ca_delsol
Jul 29, 2005 11:20 AM
Ill Mitch
Jan 31, 2005 07:43 PM
Eluzion
Apr 19, 2004 11:14 AM
raymondcleung
Mar 14, 2004 06:03 PM
Acc91ord
Mar 3, 2002 05:54 PM
