Problem with wiring
Well... I have EG Civic `94. with D16Y8 (`98). Befor upgrade, my Civic was with D13B2 engine.
Main Parts:
* D16Y8 Engine
* D16z6 Intake manifold
* D16Z6 Wiring (engine)
* D16Z6 ECU
* D16Y8 Distributor
So far all is o.k. My auto runs very well, but I have a BIG problem: The CRANK POSITION SENSOR is going out of order (ECU shows the CODE 4).
I will try to ilustrate the problem: When my auto is hot (temp. NORM), and I`m not push the accelerator (~700rpm), my Civic is working for some seconds and then suddenly stifle. I turn on the Ignition and the Civic is working again.
I have change the CP sensor and my car was o.k (no ECU error codes) for a 1,5 monthes and now, the same situattion.
So, My technics can`t help me. PLEASE help with info. I think there is a problem in Wiring. Some thing is wrong, but I don`t now what.
Please post or send me by E-mail a WIRING DIAGRAMS FOR D16Y8 and D16Z6.
Info about My Civic: http://www.cardomain.com/id/marissio
My e-mail: marissio@e-no.lv
Thank`s in advance
Modified by marissio at 2:41 PM 9/16/2004
Main Parts:
* D16Y8 Engine
* D16Z6 ECU
* D16Y8 Distributor
Thank`s in advance
Not too sure on what the problem could be. It may be that for some reason the z6 parts are not woprking with the y8 parts. Or there could be a short somewhere. Have you tried a new ecu?
Yes, I have tried. My ECU is chipped, that`s mean, that`s my ECU don`t show me any CODES. When I changes ECU, the other one shows CODE 4.
I think, that`s there is a diference between D16Y8 and D16Z6 wiring. I know, that there was a difference, but there is more
Where I can found a wiring diagrams for D16Y8 and Z6?
Root79
25
Oct 21, 2005 09:35 AM
