What is considered perfect compression for a JDM H23A DOHC VTEC???
Old Sep 16, 2004 | 12:21 AM
H23AHybridEG's Avatar
Default What is considered perfect compression for a JDM H23A DOHC VTEC???
I finally got around to compression testing my JDM H23A DOHC VTEC, and the readings were 215 in all four cylinders. I know that the compression is good, but what is considered perfect?
...and what is even more strange is that I got the engine from Osaka JDM Motors
Old Sep 16, 2004 | 01:50 AM
4bidden's Avatar
Default Re: What is considered perfect compression for a JDM H23A DOHC VTEC??? (H23AHybridEG)
The same number is all 4 cylinders = perfect.
Old Sep 16, 2004 | 05:03 AM
OTT's Avatar
OTT
I have a JDM H22a 4g Prelude, I got it with 25,000 miles on the clock so it is still pretty new, only got 35k on it now.
When I first got it I did a compression test and got straight 260psi reading across all four.
JDM H22a is 10.6:1 Compression Ratio
yourumbers seem a bit low. 215. How many miles on the engine did they tell you??
Old Sep 16, 2004 | 05:52 AM
Default Re: (OTT)
The engine is practically brand new. What do you think about what 4bidden said?
Old Sep 16, 2004 | 07:29 AM
GaRn's Avatar
Default Re: (H23AHybridEG)
elevation?
Old Sep 16, 2004 | 07:34 AM
Default Re: (GaRn)
I am in Illinois by Chicago...I don't know the exact elevation...
Old Sep 16, 2004 | 08:06 AM
monalisa overdrive's Avatar
actually i think 215 is right around where you wanna be for an h23. don't quote me on that, but if i recall correctly you're fine. besides, uniform compression is what you want.
Old Sep 16, 2004 | 08:25 AM
Default Re: (monalisa overdrive)
My engine builder (at CJ-Motorsports) knows what he's doing, and he told me that I have EXCELLENT compression...what do you guys think?
Old Sep 21, 2004 | 08:16 AM
mister2racer's Avatar
260 is ****** nuts... you must have cranked the engine until the gauge stops going up.
215 was from H23AHybridEG's motor from the standard 4 cranks.
Old Sep 21, 2004 | 08:43 AM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monalisa overdrive &raquo;</TD></TR><TR><TD CLASS="quote">actually i think 215 is right around where you wanna be for an h23. don't quote me on that, but if i recall correctly you're fine. besides, uniform compression is what you want.</TD></TR></TABLE>
I think it's more like 180-185 across the cylinders for an h23
Old Sep 21, 2004 | 09:14 AM
Monkey Fing a Coconut's Avatar
Default Re: (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">
i would assume though that the h23a would come with higher comp pistons than a h23a1, similar to h22 ones
Old Sep 21, 2004 | 09:53 AM
OTT's Avatar
OTT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H23AHybridEG &raquo;</TD></TR><TR><TD CLASS="quote">The engine is practically brand new. What do you think about what 4bidden said?</TD></TR></TABLE>
Thank, it is (and its hella fun ). And 4bidden is right, straight numbers across the board is ideal showing the engine has healthy rings & valves although your compression seems low to say its a H23aVTEC.
I'd assume it would have at least what the JDM H22a has stock. But then again it might just be because your engines done a lot of miles(?) either way you've got a great starting point for a built motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GaRn &raquo;</TD></TR><TR><TD CLASS="quote">elevation?</TD></TR></TABLE>
Below Sea Level/Sea Level the ball is in my court again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H23AHybridEG &raquo;</TD></TR><TR><TD CLASS="quote">My engine builder (at CJ-Motorsports) knows what he's doing, and he told me that I have EXCELLENT compression...what do you guys think?</TD></TR></TABLE>
I think you should fully build your motor allmotor high compression.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mister2racer &raquo;</TD></TR><TR><TD CLASS="quote">260 is ****** nuts... you must have cranked the engine until the gauge stops going up.
215 was from H23AHybridEG's motor from the standard 4 cranks.</TD></TR></TABLE>
No.
You could crank it forever and all you'd get would be a burnt-out starter and the same pressure reading as you would have got if you did it the proper way (4cranks per cyl).
H23AHybridEG/mister2racer
When you did the test did you hold the throttle wide open as you cranked it?
Old Sep 21, 2004 | 05:25 PM
his motor has perfect compression... the dyno graph is amazing and the motor is mint. there is no point to keeping this thread alive.
Old Sep 21, 2004 | 06:48 PM
fastludeh22's Avatar
Default Re: (mister2racer)
just for referance the helms says usdm 10:1 brand new = 185, 215=~10.5:1, 260= hell of carbon build up
Old Sep 21, 2004 | 06:57 PM
yOnKiNaToR's Avatar
Default Re: (fastludeh22)
my jdm h22 from hmotors is pumping 215 on all 4 also.
Old Sep 21, 2004 | 07:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 &raquo;</TD></TR><TR><TD CLASS="quote">just for referance the helms says usdm 10:1 brand new = 185, 215=~10.5:1, 260= hell of carbon build up</TD></TR></TABLE>
It's a JDM H23A...not the USDM H23A1. Also, the compression is 10:6:1...
Old Sep 21, 2004 | 07:23 PM
SKDRCR's Avatar
It's a JDM H23A...not the USDM H23A1. Also, the compression is 10:6:1...</TD></TR></TABLE>
Well there ya go, 10.6:1, 215 across. Looks like you have a healthy motor
Old Sep 21, 2004 | 07:26 PM
ya i know but the #'s are still the same. i should have worded better, 185=usdm h22a1=10:1, the rest were going by my personal experince
Old Oct 4, 2004 | 09:51 AM
leprekhan's Avatar
Default Re: (twistedbydezign)
An H23a is hondas highest tq producer. and i'm almost sure of the fact that it has a higher compresion than an h22 or f22 for matter
Old Oct 4, 2004 | 10:08 AM
Default Re: (leprekhan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leprekhan &raquo;</TD></TR><TR><TD CLASS="quote">An H23a is hondas highest tq producer. and i'm almost sure of the fact that it has a higher compresion than an h22 or f22 for matter
Actually the compression is 10:6:1
Old Oct 4, 2004 | 10:56 AM
yohan's Avatar
those numbers are great for 10.6:1 compression, which I am pretty sure where the H23A vtec is at...
Your engine is fine man ... all the numbers came out the same, beauty
H23 USDM STock DOCH Non Vtec 9:1 compression is happy with ~180 to be considered new ..
My JDM H22 supposedly was 210 accross the board when it compression tested but.. until I put the gauge on it myself .. pfft.
Shanemoore9
Feb 27, 2013 09:39 AM
Greyout
Apr 27, 2006 12:56 PM
93H22APrelude
Jul 31, 2005 05:30 PM
Slava.
Sep 15, 2003 10:02 AM
H22ACiViC
Mar 9, 2002 03:05 PM
