odyssey came in for an oil change and left with a new motor -- -- ouch
Old Sep 15, 2004 | 10:42 PM
beerz's Avatar
Default odyssey came in for an oil change and left with a new motor -- -- ouch
i thought i'd tell my story. im the mechanic and i feel bad for the customer. the car came in for an oil change and they asked to check where the oil leak was coming from. it is a honda odyssey, 1999, 3.5 liter V6 with 53k miles on it. well as you may now these motors have a problem (im not sure how common) of the aluminum block cracking either by the water pump (passenger side), above the rear main seal by certain bolts (driver side), and in the valley under the intake between the two heads. well the oil was running all down the front of the motor and on top of the transaxle and there was puddles of oil in the valley. so i read up on the bulletin and find out what honda recommends to fix it. believe it or not honda recommends JB welding the cracks, okay, we get some JB weld. i start to pull the the motor apart and it turns out to remove the lower intake manifolds you must pull the head because the two center studs holding either side on are in the way (horrible design in my opinion.) short cuts i think, not enough room to double nut the studs, no room for stud removers, thought about vise grips, nah, thought about welding the nut to the stud and backing out the stud, nah. the job pays well so i decide not to take the short cut and i pull the head (great decision as it turns out you will soon see). this is the head towards the front of the car. i get it all apart and im about to remove the head bolts. the first one i try was finger tight, if that. and now i have opened pandoras box. the rest are torqued correctly. so it turns out the bolt that was loose (rear driver side corner bolt) was right next to the oil passage into the head. well obviously thats where the oil leak was coming from, and im damn glad i didnt try any short cuts to not remove the head. i inspected for cracks anyway inside the valley and found nothing. after pulling the head and inspecting i found that there was metal shavings inside the bolt hole and the bolt would not thread correctly. i tapped it but there was just not enough material to hold the bolt to torque spec. so we give the customer the option to try and repair the threads using a helicoil (im not sure that there are any specialized kits for this sort of thing) but we can not warranty it if the helicoil should back, leak, out or it doesnt work for some reason or another, or to replace the block. so they opt for door number two. and that is how a 1999 honda odyssey with 53000 miles on it needs a new motor. so what do you all think about that. any ideas on fixing the threads? damn i feel bad for the customer because thats why you buy new cars so you dont have to go through stuff like this. its hard to believe that that bolt was left loose from the factory, but i dont know why someone else would have been in there with only 53,000 miles and there are no records of the heads being removed. i did see other bolts cross threaded while removing the motor though so i guess anythings possible, sobotage? who knows. the car ran just fine as well, just leaked alot of oil. well thats that, i get to new put the short block back in tomorrow. i just thought i'd let all of you know in case anyone else has an oil leaking odyssey. have agood one.
swig
Old Sep 15, 2004 | 10:58 PM
dantastic's Avatar
great story
Old Sep 15, 2004 | 10:59 PM
rodrez.'s Avatar
Default Re: odyssey came in for an oil change and left with a new motor -- -- ouch (beerz)
Probably want to post this in the Odyssey/Other forum.
Edit: nevermind, you already did
Old Sep 15, 2004 | 11:56 PM
beerz's Avatar
Default Re: odyssey came in for an oil change and left with a new motor -- -- ouch (rodrez)
yeah i put it here to because i figured it would get more views and the main reason i posted it was to see if anyone else has encountered similar problems. thanks for your time though.
Old Sep 16, 2004 | 03:34 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">great story </TD></TR></TABLE>
What a dick, hes just trying to be a nice guy and let people know whats up. Maybe people in this EG forum actually have Oddessy's too? thanks for being a Dicknose
Old Sep 16, 2004 | 04:11 AM
gulftiresinc's Avatar
Default Re: (b2o-vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b2o-vtec &raquo;</TD></TR><TR><TD CLASS="quote">
What a dick, hes just trying to be a nice guy and let people know whats up. Maybe people in this EG forum actually have Oddessy's too? thanks for being a Dicknose </TD></TR></TABLE>
thx man i will talk to ppl about this porb!
EM2_PLo
Honda Civic (2001 - 2005)
14
Apr 21, 2010 09:28 PM
neophyte210
13
Dec 4, 2007 04:53 AM
92redhatch
Aug 27, 2006 09:52 AM
beerz
Acura TL, RL & ZDX
Nov 4, 2004 11:59 PM
return_2020
Jul 19, 2004 06:14 AM
