timing belt snaped !!
Old Sep 15, 2004 | 10:41 PM
andlude's Avatar
Default timing belt snaped !!
my timing belt snaped on my way home a couple days ago, whats the chance it blew the motor... it did make a couple sounds before turning off?
Old Sep 15, 2004 | 10:42 PM
PrecisionH23a's Avatar
Default Re: timing belt snaped !! (andlude)
A piston most likely made contact with a valve or 16 and bent them causing you to not be able to create compression.
You may be lucky though. Go ahead and throw another timing belt on and see if it cranks then do a cyl leakdown test. If it won't start, go ahead and yank the head, send it off to be inspected and also look to make sure your pistons are ok.
Old Sep 15, 2004 | 10:43 PM
speedracer9k's Avatar
i snapped my timing belt a while ago, and the motor was fine, but it did not make any sounds before it died, so i dont know what to tell you
Old Sep 16, 2004 | 02:07 AM
red92si's Avatar
You most likely will have at least a few bent valves. A timing belt snapping is one of the worst things that can occur. Here is a pic of a friend of mine's H23 from a few years back... timing belt went one day and bent all 16 valves, and broke a rocker arm; which he is holding in his hand.
Old Sep 16, 2004 | 07:27 AM
MechEng's Avatar
Default Re: (red92si)
How many kms did you have on the belt.
I've found that they can last much longer than 100,000km
Old Sep 16, 2004 | 09:07 AM
93H22ACX's Avatar
Default Re: (MechEng)
you will probably have a bent valve. mine snapped and we thought it didnt bend any valves so we put a new t-belt on. car ran fine but shook a little at idle...did a compression test..300...300...295...0
do a compression test
Old Sep 16, 2004 | 06:35 PM
Qfactor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red92si &raquo;</TD></TR><TR><TD CLASS="quote">
I also think you should change your oil more often...damn that looks like La Brea Tar pits down in Exposition Blvd.
Old Sep 16, 2004 | 09:46 PM
andlude's Avatar
Default Re: (Qfactor)
i dont have the time or money to fix it so i bought a shitty ef and im gonna swap an h22 intothe lude over winter... i was sick of the h23 anyway,plus i wanted a winter car. but dont worry i didnt give up on the prelude, i love it
Old Sep 17, 2004 | 07:09 AM
Pre1ude's Avatar
you definately bent a valve or 16 all hondas have an interference head which means that at TDC the valves (if open) will touch the piston head.
Cripton805
Jan 9, 2022 07:15 PM
Gvis420
13
Dec 20, 2009 12:24 PM
JSpekBB4
Sep 1, 2006 08:18 PM
00siALLmotor
Acura TL, RL & ZDX
Jan 30, 2005 09:31 PM
NateTEG95
Jul 23, 2003 12:31 PM
