Another integra dash swap question
I have done a search here on Honda-tech, nothing help ful. I've searched on google and a lot of other places.
I know the basics of swapping the integra dash into a EG. What I want to know if there is anything major i need to do? Also do i use the civic heat system or the integra one? Just so I know if I need to buy anything else when i buy the dash.
As for people I have read with problems with the door panels, there is something you can do yourself to make it work. I know the secret and its not hard. I can share that part with anyone who can guide me on the actual dash swap itself.
thanks
thanks
What you need to get is all the parts of the dash, and get the 94-95 teg dash harness. For the harness, use the complete teg dash harness, and just swap the grey pins out. Unpin the grey plug from the teg harness and match the pinouts to the civic grey fuse box plug. You will have a blk/yel wire leftover as well as a blue. Let the blue dangle, and splice the yel/blk wire into the yel wire in the middle of the green fuse box plug. This will make your turn signals work. That is all you need to do as for wiring
When I did the swap, I used the factory civic side mounts and retained all factory mounting holes. Just trim the inside crevice till everything fits perfectly and lines up on the sides. Behind the cluster you will have to cut out all the plastic on the dash to clear the civic steering column support. As for heater/ac, I have heard to use the civic setup, but I don't run a/c or heater in any of my vehicles so I'm not positive. Best of luck and feel free to IM me if you need any more help
I think the plastic piece that comes off the integra heater core, I think your gonna need that, and dont hook up your dimmer switch till you have done more research or else it will fry out
Dancing is Forbidden
Oct 4, 2003 09:56 AM
