Some body that speak spanish?
Narrow Band throttle, and Wide band throttle. Adjusting Narrow band will -/+ the percent of fuel at a given RPM point, when below 50 percent throttle. Wide Band adjustments allow -/+ of fuel at 100% throtte. I recommend you not adjust your SAFC if you don't know what these things do, unless you're running too lean, you can add a few % of fuel across the RPM band.
ekhatch66
Engine Management and Tuning
Aug 19, 2009 09:14 AM
adamsjm5
Nov 20, 2006 04:22 PM
