Roll cage....00 civic hb...
what I am looking for is......is there any company that makes the front "A" pillar bars that come from the rear main hoop behind the driver head, and comes forward and makes the bend to go down the windshield and into the air vent on the top side of the dash? You can see in my rough sketch of the red lines. I need the bar that goes from the rear hoop, beside the drivers head and down through the dash air vent for a 2000 Honda civic hb. Also needs to be 4130 chromo...1 5/8" OD.
dont think anyone pre makes anything to go through your vent! your gonna have to remove your dash if you want a bar through it. call your local fab shop.
jason im telling you take it to coastal chassis dyno, they can fabricate anything, and are so far the best i have seen in my opinion, plus they arent too high priced, they are doing my cage
http://www.artmorrison.com has pre-fabbed cages. not sure if this is what your looking for but thought id post the site anyways.
In most cases, trying to get a bar to go through a vent or top of the dash is going to be difficult. The dash and wind shield will most likely need to be pulled. Remove the excisting dash bar (steering column mount) fit and trim all componets and then put it all back together. It will take some time and effort. We do all of our cages that way and speaking from experience it is the only way.
Since you live drag racing territory, it shouldn't be hard for you to find a shop that can do that.
going to have to be custom. honda challange racers run there cages like this most of the time. you can leave the windsheild in but dash must be removed
carlosjdmcivic
27
Apr 17, 2010 04:46 PM
