Is it worth it to bump compresson up 0.2 ???
Old Sep 15, 2004 | 05:11 PM
slowsleeper's Avatar
Default Is it worth it to bump compresson up 0.2 ???
Ok, I did an estimated compression check on the c-speed site, planning on running a gsr with about 0.025 piston to deck, the difference between an OEM head gasket and a 2 layer one comes out to be 10.12 for OEM and 10.36 for 2 layer head gasket....
Would it be woth it to buy the Mugen or Spoon for the 0.2 bump? Is it safe to just run one layer gasket from the OEM one instead of three, because if I pick the 1 layer, the comp goes to 10.6....does any manufacturer make a 1 layer gasket?
Old Sep 15, 2004 | 05:39 PM
Odiedogcx's Avatar
AIRBORNE
Default Re: Is it worth it to bump compresson up 0.2 ??? (slowsleeper)
I'd also like to know
Old Sep 15, 2004 | 06:16 PM
DefiantGSR's Avatar
Default Re: Is it worth it to bump compresson up 0.2 ??? (Odiedogcx)
a 0.1 bump in compression will theoretically give you a 1% power increase. The rest is up to you to decide whether it's worth it or not.
Old Sep 15, 2004 | 08:04 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: Is it worth it to bump compresson up 0.2 ??? (DefiantGSR)
Sure, why not?
98vtec
Feb 12, 2006 11:30 AM
rough_draft
May 5, 2004 12:53 AM
1990hondaHF
Apr 8, 2004 11:13 PM
TBoy1
Aug 21, 2003 11:33 AM
b18cTurbo
Feb 15, 2003 12:33 PM
