92 prelude, right front wheel seems to be locking up
Old Sep 15, 2004 | 05:03 PM
preludacris22's Avatar
Default 92 prelude, right front wheel seems to be locking up
I just recently changed my right cv joint and had no probs for a couple weeks. If i jack up the right side first i cant turn the right wheel, but if i jack up just the left and turn the left side wheel, it turns. Now if i jack up the whole front both wheels turn, as if it had positract or something. And on the turns the car pops like hell and seems like the right wheel is skidding. Any thoughts, please help, maybe tranny problem?
Old Sep 15, 2004 | 06:52 PM
dc5r2002's Avatar
Default Re: 92 prelude, right front wheel seems to be locking up (preludacris22)
bad wheel bearing? that could explain why you just replaced the whole axle i am assuming
Old Sep 16, 2004 | 02:41 AM
Default Re: 92 prelude, right front wheel seems to be locking up (Pulp Fiction)
how much are wheel bearings, how hard are they to put in, and can i get them like at autozone?
Old Sep 16, 2004 | 04:48 AM
OTT's Avatar
OTT
how much? nearest figure i can give you is Expensive.
You use a hydraulic press to insert or remove the central hub from the steering knucles. and the bearings are pressed in between the two.
Old Sep 16, 2004 | 05:01 AM
dc5r2002's Avatar
Default Re: 92 prelude, right front wheel seems to be locking up (OTT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OTT &raquo;</TD></TR><TR><TD CLASS="quote">how much? nearest figure i can give you is Expensive.
You use a hydraulic press to insert or remove the central hub from the steering knucles. and the bearings are pressed in between the two. </TD></TR></TABLE>
they are only about $50 at a pepboys or somewhere else like that, getting it out is going to be a bitch, if you are going to do it yourself you might just want to replace the whole hub, if you dont press the bearing in 100% correct the first time you will replace it again a few weeks later, belive me I just had to on my teg a few days ago, also if you dont have access the the press or a bearing splitter or know a machine shop or someone who does its not happining.
soclean1k_JDM
Suspension & Brakes
11
Mar 23, 2010 09:40 PM
uneek4dr
Apr 24, 2006 01:12 AM
.bagged
Nov 4, 2004 07:31 PM
Mr. Vapor
Dec 5, 2002 05:29 PM
OneThirtyEight
Oct 30, 2001 06:03 PM
