wiring dual point o multi point injection questions... HELP
Old Sep 15, 2004 | 02:00 PM
red civic's Avatar
Default wiring dual point o multi point injection questions... HELP
I have a 90 civic hatch DX, 1.5 liter non vtec, I swapped this out to a SOHC vtec 1.6 liter. I used a 91 Si wiring harness and a 91 Si computer, but didnt change the inside wiring harness. Does anyone know what wires i need to change at the ECU to make this work?
Any information would greatly be appreciated.
Thanks
Old Sep 15, 2004 | 02:04 PM
Mr_CRX's Avatar
Default Re: wiring dual point o multi point injection questions... HELP (red civic)
Use your DX harness and modify it. Its easier to do that than to use the Si harness.
http://fourthgenhatch.com/mpfi.html
I used this site when I did my swap.
Good luck!
Old Sep 16, 2004 | 06:29 AM
red civic's Avatar
Default Re: wiring dual point o multi point injection questions... HELP (Mr_CRX)
thank u for all your info .ill work on the car tonight and ill let you know what the results are tomorrow.thanks again
Old Sep 16, 2004 | 06:36 AM
manson's Avatar
good luck... its not very hard.
Old Sep 16, 2004 | 01:37 PM
red civic's Avatar
Default Re: wiring dual point o multi point injection questions... HELP (manson)
i did everything the diagrams told me to do but the car will not start ... if there is anything else i have to do please let me know...this car is starting to **** me off!!!!
Old Sep 16, 2004 | 04:48 PM
mr. carpenter's Avatar
are you doing a dual point to multi point or a z6 swap?
Old Sep 16, 2004 | 08:35 PM
red civic's Avatar
Default Re: wiring dual point o multi point injection questions... HELP (mr. carpenter)
dual point to multipoint... I had a 1.5 non v-tec and swapped it out with a 1.6 sohc v-tec zc and i need help with the wiring at the ecu... Please help me!!!!!
Old Sep 16, 2004 | 08:41 PM
Mr_CRX's Avatar
Is it cranking at least? Do you have spark? fuel?
Old Sep 16, 2004 | 09:02 PM
red civic's Avatar
i really dont understand it i have spark and fuel and it cranks i really dont understand why its not starting!!if u have anymore diagrams it would be greatly appreciated... Thanks
Old Sep 16, 2004 | 09:14 PM
ihateslowhondas's Avatar
check your plugs and stuff, maybe its flooded. double check your plug wires and rotor position.
Old Sep 17, 2004 | 07:25 AM
tgreaves's Avatar
Put a timing light on it and get someone else to crank it over.. You might have the 2 blue wires reversed when you wired up the dizzy and that will throw you ignition timing wayyyyyy out..
mikezcdx
Mar 9, 2006 07:16 AM
91CRXjunkie
Aug 21, 2005 11:12 PM
red civic
Sep 15, 2004 01:11 PM
speed_racer012
Oct 22, 2003 06:31 AM
