Accord connecting rods?
Old Dec 9, 2001 | 03:31 PM
MisterB's Avatar
Default Accord connecting rods?
Does anyone know if there is any rods for an F22B turbo. I called eagle and crower and they both said they dont have them and they can not make them, so i was thinking of shot peining the stocks but that wont last with lots of boost so any help or suggestions would be great.
Old Dec 9, 2001 | 04:17 PM
97accordex's Avatar
Default Re: Accord connecting rods? (cl4show)
I am thinking of turboing my f22 this coming spring. F-Max makes the only kit that I have seen for the f22. I am not real swift with a wrench so a kit and a mechanic is the way for me to go.
But in general, I do not think that the f22 is a popular motor to build,,, sohc and vtec. You can get lots of after market parts for it,, and the F-max kit for low boost etc. but no serious race parts that I have seen. Maybe they are out there but I think the civics have a lot more stuff available for them.
I think that you need to go with the H22 or one of the civic B series.
Old Dec 10, 2001 | 08:42 AM
MisterB's Avatar
Default Re: Accord connecting rods? (accordy2g)
what a bunch of punks... thanx for your help btw how is your f23 with the turbo doing i have an fmax kit on f22b 2.2CL at 9psi and it blew in like a month piston rings and bent valve
Old Dec 10, 2001 | 09:39 AM
DLB1994's Avatar
why are u going to 8.5:1 so low its going to be so slow in to it hit boost
in my h23 i went up to 10.1: so i get full boost @ about 3500 on a .63 exhousing
if i was u i would go up to at least 9:5 its better to make more power at low boost then make the same power at high boost
Old Dec 10, 2001 | 02:26 PM
MisterB's Avatar
you will have less of a chance of detonating which is good but your off boost power will be bad which is ok if your car can handle boost all the time... what is you stock CR i think im going to keep my CR the same with Arias pistons...let me know what rods your going to go with and how much they will cost.
Old Dec 14, 2001 | 03:13 PM
MisterB's Avatar
I called crower and they said they have something that will fit so i am going to go with arias pistons 8.5:1~8.8:1, crower rods, intank fuel pump, rising rate fpr, mf2 (from Fmax kit)how much boost do you think i can run on this set up daily, and how much at the track?
broketuner-Sol_Si
Jun 20, 2007 12:44 PM
Turbo O
Feb 1, 2006 02:56 AM
RHD_BB4T
Feb 15, 2003 03:57 PM
6GACCORDH22
Nov 14, 2002 04:32 PM
Veil_Side_
Jan 30, 2002 04:00 PM
