Help! Speedo went bezerk and then guages turned off while driving down highway!
Then My car stalled at a light and a stanger had to jumpstart me. Even then the car would run, but my turn signals and guages would not work. I heard a funny sound under the dash, but have checked all the fuses and they seem ok.
I checked the VSS-vehicle speed sensor and it was fine, in place.
Car has a b18b swapped into it with I/H/E.
-Any help is greatly appreciated.
-Edward
-Edward
I checked the big fuses under the hood near the firewall. This just suck because I paid $2k for the swap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Edwardo911 »</TD></TR><TR><TD CLASS="quote">I checked the big fuses under the hood near the firewall. This just suck because I paid $2k for the swap.</TD></TR></TABLE>
Check the fuses under the dash. Had the same **** happen to me. Ended up poppin 2 fuses.
cool, thanks I'll check agin. it's perilous place to check fuses when your stuck on the side of a superhighway!
Honestly, Anyone wants it, I'm ready for a new car! $2500 and it's yours...
Happened to me and the connection to the alternator was loose. There is a nut under a rubber cap on top of the alternator. Make sure the connection is tight. Check the easy stuff first. Check voltage also to see if it's the alternator.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Edwardo911 »</TD></TR><TR><TD CLASS="quote">Honestly, Anyone wants it, I'm ready for a new car! $2500 and it's yours...</TD></TR></TABLE>
What color and how many miles?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PLANBmotorsports »</TD></TR><TR><TD CLASS="quote">Happened to me and the connection to the alternator was loose. There is a nut under a rubber cap on top of the alternator. Make sure the connection is tight. Check the easy stuff first. Check voltage also to see if it's the alternator.</TD></TR></TABLE>
where would you check the voltage at? the battery? cause im having the same problem.. but more severe and i changed the alternator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoT HaTcH »</TD></TR><TR><TD CLASS="quote">
where would you check the voltage at? the battery? cause im having the same problem.. but more severe and i changed the alternator</TD></TR></TABLE>
Yes, check your thread. Get a multimeter and test at the battery. Should be around 12.2v with the car off, and 14.4ish with the car on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">
Yes, check your thread. Get a multimeter and test at the battery. Should be around 12.2v with the car off, and 14.4ish with the car on. </TD></TR></TABLE>
12.2 is just the battery hence a 12v battery. reason for 14.2 is alternator supplies more power. if the car is on at 12.2, the alternator isn't contributing. check the connection.
Yeah yeah, showoff.
</TD></TR></TABLE>Yeah yeah, showoff.
Hey if anyone knows their stuff, it's you Ricey. Hopefully it is just the connection though. I got lucky.
Bright Milano red. Has a fiberglass hood-matching red, Aem short ram intake, hight flow cat, Greddy Power Extreme Exhaust. New AC compressor and monting parts. The chassis has about 107,000 miles, as for the B18b.ls motor, I am unsure of the mileage.
I Have pics if interested. The car looks nice, exhaust sounds good, but, it does have this problem, which seems to be electrical in nature-it may just need a new alternator.
-Edward
(469) 583-6441
-Edward
(469) 583-6441
