Head light Beam adjustment (searched)
I couldn't find anything about the beam adjustment. I got a new headlight and it points upward. Im brightlighting every one. I see there is a little gear looking thing at the bottom back side of the light. Is this how I adjust it? If so what do I use to turn the gear?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Home Skillet »</TD></TR><TR><TD CLASS="quote">There is a phillips screw on the front topside of the light. That should adjust it for you. </TD></TR></TABLE>
YUP. thats the up/down adjustment. The gear is for left to right
use a long phillips head screw driver. Just insert in right in and it'll mesh with the gear. then turn it left or right depending which way the light needs to go.
