weird weird problem, need help
ok, for the past 2 weeks iv been driving on the high way alot, and everyday, while im cruising in 5th gear the car like shuts off, feels and sounds like i just let off the gas.. i push the gas, nothing, no go and no rev, but when i push the clutch in and out its all good and i can keep driving
its like when ur going down the street and u turn ur car off going in what ever gear, and u put it to the "on" position and push the clutch and it starts back up... seems to be just like that
anyone ever heard of this? please help me
EDIT: i thought maybe it was the tranny cuz i just swapped it, and maybe it was slipping out of gear... but its not, it stays in gear and when i push the gas it doesnt even rev
Are you getting a CEL? Do you have any problems with the speedometer? I had that happen when my Vehicle Speed Sensor was broken. The car would die on the freeway for a couple of seconds and then out of nowhere is would have power again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShadyEH2 »</TD></TR><TR><TD CLASS="quote">i'm gonna say check the tranny ground, and if it's fine, then you might have a bad ignition switch</TD></TR></TABLE>
imma have to say its the ignition switch or somthing to that sort
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spids5 »</TD></TR><TR><TD CLASS="quote">Are you getting a CEL? Do you have any problems with the speedometer? I had that happen when my Vehicle Speed Sensor was broken. The car would die on the freeway for a couple of seconds and then out of nowhere is would have power again.</TD></TR></TABLE>
i have a bad VSS, i hope thats the problem, was it ok after u got it fixed?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tallblondkid »</TD></TR><TR><TD CLASS="quote">
i have a bad VSS, i hope thats the problem, was it ok after u got it fixed?</TD></TR></TABLE>
Yes it never happen again. The weird thing about it was that the CEL wasn't on but it would still die anyways when the VSS was broken.
tallblondkid
14
Sep 16, 2004 03:10 AM
tallblondkid
Sep 15, 2004 01:24 PM
