Greddy Electronic Gauges
Old Sep 14, 2004 | 09:56 PM
billyhoe's Avatar
Default Greddy Electronic Gauges
i have 4 greddy gauges oil pres. (0-10kg), fuel pres. (0-6kg), EGT, and coolant temp. im not sure the gauges are reading correctly because the sensor wires run along the ignition wires which the manual says not to do but i have no choice and just need feedback. My fuel press seems rather normal 3.5kg max, but my oil pressure gauge acts more like an rpm gauge. While accelerating i notice the oil pres. gauge goes up to 6.0kg then drops to 5.0kg. Is that normal or is the sensor wire to close to the ignition wires? i read in the manual oil pres. should be 10 psi at idle in which case my gauge reads 2.0kg which im pretty sure is more then 10 psi.
Kwayzie
Oct 25, 2006 07:04 PM
Si Shane
Oct 20, 2005 02:47 PM
jaymes2030
Oct 9, 2003 10:30 AM
vtec69
Mar 12, 2003 10:31 PM
vtec69
Mar 12, 2003 05:54 PM
