Huge Problem with Mahle Pistons Quality...anyone else?
Old Sep 14, 2004 | 09:39 PM
earl's Avatar
Default Huge Problem with Mahle Pistons Quality...anyone else?
Here is an 87mm Mahle piston given to me by a customer for an H series build. A nice strut design but it is almost .100" too narrow to ever fit a Pauter rod.
The box says the pistons were 9-1 but I have never seen a Prelude 9-1 with a dome. It should have about a -7cc dish. Also the valve reliefs are very shallow.
Oh yeah, one last thing...one skirt was .020" thicker that the other skirt.
Worst quality control I have ever seen.
If this is F1 technology, I think I'll pass
Anyone else have a good or bad experience with Mahle?
Old Sep 14, 2004 | 10:29 PM
PrecisionH23a's Avatar
Default Re: Huge Problem with Mahle Pistons Quality...anyone else? (earl)
I didn't even know mahle made pistons for the H series motor?
Here is a snap of the CP's we used in a build Mase and I did.
Here's another snap of some JE's for an h23a.
My custom CP 88mm's also have the - dish as well. You are correct though, every 87mm shelf piston I have seen for the H series have a small dish. I'm assuming that is a graphite coating on the Mahle piston skirts. Possibly that is what is throwing the skirt dimensions off? Does the piston come with the piston to deck height specs by any chance?
You may want to call mahle because I believe they use a "ferrostan/ferroprint" coatings depending on the type of application cylinder bore. We all know the H series have the nikasil FRM lined walls so I don't know if they took into account the new set-up will be for an iron ductile sleeve or not.
See what I'm talking about with having customers bring you parts? hehe.
Old Sep 14, 2004 | 11:08 PM
rioninja's Avatar
Earl, what does the customer plan on doing with the pistons at this point?
Is it feasible to machine the rods? From the looks of the pic, it looks as though
a stock rod would barely have enough clearance... Looks like a case of parts being
released with little to no r&d time... shame, this is not what i like to see.
Old Sep 14, 2004 | 11:10 PM
rioninja's Avatar
Also, any chance that these pistons have a lower overall height as compared
to the stockers (and as it appears the CPs)? That may explain the dome instead
of dish, and less than adequate appearing valve reliefs..
Old Sep 15, 2004 | 04:50 AM
tony1's Avatar
Earl, I thought you knew what you were doing? You gotta tap the rod in the piston with a rubber mallet. If it gives you trouble then get a bigger hammer.
Old Sep 15, 2004 | 05:04 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: Huge Problem with Mahle Pistons Quality...anyone else? (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Earl, I thought you knew what you were doing? You gotta tap the rod in the piston with a rubber mallet. If it gives you trouble then get a bigger hammer. </TD></TR></TABLE>
DUHH
Old Sep 15, 2004 | 07:11 AM
earl's Avatar
Default Re: Huge Problem with Mahle Pistons Quality...anyone else? (rioninja)
These pistons will not work even with a stock rod.
I'm not willing to take the liability of modifying the pistons to fit.
Plus the compression ratio is way off on them. I wish I knew what they were thinking when they made this piston.
Old Sep 15, 2004 | 07:13 AM
Ekasey's Avatar
Default Re: Huge Problem with Mahle Pistons Quality...anyone else? (si2die4)
A technicians best friend a BFH (big ******* hammer)
I see what you were speaking of Earl not that I didn't belive you, just thought mhale would have had alot better quality
Old Sep 15, 2004 | 08:19 AM
b18cls1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">Here is an 87mm Mahle piston given to me by a customer for an H series build. A nice strut design but it is almost .100" too narrow to ever fit a Pauter rod.
Anyone else have a good or bad experience with Mahle?</TD></TR></TABLE>
ive never used mahale in a honda but use them in porsche engines all the time and they make some good pistons, ive never had that happen, and hopefully you wont judge mahale off of just that set.
i would send them back and get a new set.
Old Feb 15, 2005 | 06:26 AM
Shakes's Avatar
space cadet
Default Re: Huge Problem with Mahle Pistons Quality...anyone else? (b18cls1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cls1 &raquo;</TD></TR><TR><TD CLASS="quote">
i would send them back and get a new set.</TD></TR></TABLE>
was there ever any follow up on this?
Old Feb 15, 2005 | 07:56 AM
solowerks's Avatar
Mistakes happen, call them up and see what they say about it.
Old Feb 15, 2005 | 08:13 AM
legendboy's Avatar
Default Re: (solowerks)
yep, looks like somebody forgot to carry the 1
Old Feb 15, 2005 | 12:25 PM
racinskittle's Avatar
Default Re: (legendboy)
they ARE H series pistons right? It's not a mismarked box or something is it?
Old Feb 15, 2005 | 12:33 PM
Spade's Avatar
Default Re: (racinskittle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racinskittle &raquo;</TD></TR><TR><TD CLASS="quote">they ARE H series pistons right? It's not a mismarked box or something is it? </TD></TR></TABLE>
That's what I was thinking. Customer got the wrong part.
Old Feb 15, 2005 | 12:42 PM
JDogg's Avatar
Default Re: (Spade)
earl.. we have had the same issues.. check your pm's
Old Jul 19, 2005 | 01:35 PM
RudeLude's Avatar
Default Re: (JDogg)
any updates on this problem?
Old Jul 19, 2005 | 10:04 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: (RudeLude)
Is this Rick solis' secret motor build?
Old Jul 20, 2005 | 05:23 AM
Tactic$'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by legendboy &raquo;</TD></TR><TR><TD CLASS="quote">yep, looks like somebody forgot to carry the 1</TD></TR></TABLE>
&lt;---- Glad he didnt order any
Old Jul 20, 2005 | 06:40 AM
CRX T-Si's Avatar
Default Re: (Tactic$)
Just to let people know...I am a happy Mahle piston customer.
But damn...someone broght this baby up from the dead.
Old Jul 20, 2005 | 08:45 AM
RudeLude's Avatar
Default Re: (CRX T-Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si &raquo;</TD></TR><TR><TD CLASS="quote">Just to let people know...I am a happy Mahle piston customer.
But damn...someone broght this baby up from the dead.</TD></TR></TABLE>
what kinda motor and setup are u running?
Old Jul 20, 2005 | 09:33 AM
CRX T-Si's Avatar
Car specs listed on sig.
Old Jul 21, 2005 | 02:05 PM
RudeLude's Avatar
any updates on the h22a piston prob?
Old Jul 21, 2005 | 02:29 PM
Finest's Avatar
Holy! I didn't even see that!
But yea, any updates? Any info on the "new" H series Mahle pistons?
Old Jul 21, 2005 | 03:29 PM
pyrohardcore's Avatar
Default Re: (Finest)
i'm curious on updates too, cause i'm about to order a set for my H. lol
Old Jul 22, 2005 | 07:14 AM
RudeLude's Avatar
Default Re: (pyrohardcore)
ttt
