Detail info on gsr 97, where?????????
Old Sep 14, 2004 | 09:30 PM
yeegsr's Avatar
Default Detail info on gsr 97, where?????????
hi...i'm owning the 97-GSR...and i want to know more infomation about my engine
such as ecu, p72, p28 and SO ON....stuff like that....where can i find a site or a place to get infomation about it and read it up....
anyone know? thanx...
Old Sep 14, 2004 | 09:37 PM
Downey's Avatar
Default Re: Detail info on gsr 97, where????????? (yeegsr)
1997 GSR..
B18C1 (P72 head) Y80 tranny (non lsd)
10.0:1 compression
170hp @ 7600rpm
128 ft-lbs torque @ 6200
8100 rpm redline (P72)
gear ratio
1 3.230
2 1.950
3 1.360
4 1.034
5 0.787
fd 4.400
you can find almost ANYTHING if you use the search button..
Old Sep 14, 2004 | 09:42 PM
yeegsr's Avatar
Default Re: Detail info on gsr 97, where????????? (Downey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Downey &raquo;</TD></TR><TR><TD CLASS="quote">1997 GSR..
10.0:1 compression
170hp @ 7600rpm
gear ratio
1 3.230
2 1.950
3 1.360
4 1.034
5 0.787
fd 4.400
you can find almost ANYTHING if you use the search button.. </TD></TR></TABLE>
oh sweet...SERIOUSLY i did but...man...everything got mix up can really find anything...i have been using search alot i mean a lot...but sometime it good to post one for sure...thanx man
everyone got more info on gsr 97?
Old Sep 14, 2004 | 09:57 PM
BlackSage's Avatar
team-integra.net
You have an OBD-IIa B18C1.....dont really know what you are looking for, but TI probably has it
Old Sep 14, 2004 | 10:02 PM
yeegsr's Avatar
wait, wait, wait....im pretty sure my tranny is LSD man....but anyway how can i check for it..?
Old Sep 14, 2004 | 10:03 PM
yeegsr's Avatar
Default Re: Detail info on gsr 97, where????????? (BlackSage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackSage &raquo;</TD></TR><TR><TD CLASS="quote">team-integra.net
You have an OBD-IIa B18C1.....dont really know what you are looking for, but TI probably has it</TD></TR></TABLE>
thanx thanx, thanx...
Old Sep 14, 2004 | 10:14 PM
Gerbilo's Avatar
if it's a stock GS-R trans it is NOT LSD....
Old Sep 14, 2004 | 10:15 PM
Downey's Avatar
if your tranny is the original.. its NOT lsd..
easiest way to check.. pop out the passenger side axle. if u can see all the way thru.. u have lsd. if theres a bar in the middle of the hole.. its non-lsd.
Old Sep 14, 2004 | 10:32 PM
yeegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Downey &raquo;</TD></TR><TR><TD CLASS="quote">if your tranny is the original.. its NOT lsd..
easiest way to check.. pop out the passenger side axle. if u can see all the way thru.. u have lsd. if theres a bar in the middle of the hole.. its non-lsd.</TD></TR></TABLE>
i dont know....i got a rebuild 97 gsr swap...and then a month later my friend's neighboor was lookinga at it and he said "cool it's an LSD"...wtf...lol...just by looking down at the tranny?
pop out the passenger side axle? u mean take it out...dann i dont have the tool man.. well i went under the car so many time...all i see is one single axle from tranny to wheel...but on the driver side...the axle has two parts, one from the driver wheel connects by a circular (at the middle of the axle, look like a wheel about 1.5" thick where the axle boot is), and second half from the circular thing to the tranny
anyway is there any other way to identify LSD?...there should be more way
JordanCivic
Apr 14, 2008 12:33 AM
night walker
May 4, 2007 04:01 PM
EGHATCH4YA209
Oct 29, 2006 08:29 PM
gsr-2nr
Dec 3, 2003 04:07 PM
brasilracing
Nov 25, 2002 05:55 PM
