What's the Biggest Cam.......
Biggest Cam I can run on a B20 Block, with a B16 Head? With stock B20 Pistons as well. Thanks in advance
For example: Buddy Club III
Skunk 2 Stage 1's.......and so on
*I know the CTR/ITR are good, but I want more*
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all motor b20b »</TD></TR><TR><TD CLASS="quote">I ran Jun3's on my B20 with a stock bottom end.</TD></TR></TABLE>
Did you use it as a daily driver and weekend car? That is crazy
Any more info from anybody else?
you would have made better power with some toda a's or CTR's...
he may have been able to dial out enough overlap to maybe make equivilant power with the jun III's but now more really.
Also, smaller cams woulda yielded better midrange.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Used2beAb16 »</TD></TR><TR><TD CLASS="quote">he may have been able to dial out enough overlap to maybe make equivilant power with the jun III's but now more really.
Also, smaller cams woulda yielded better midrange.</TD></TR></TABLE>
This is why i said "better power" instead of peak power. Mid range is what counts on a street car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BryanPendleton »</TD></TR><TR><TD CLASS="quote">how do you determine the "biggest" cam? I thought they were all the same size, afterall they have to fit the same head.
the lobe size's are bigger and lift and duration are different for starters
</TD></TR></TABLE>the lobe size's are bigger and lift and duration are different for starters
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ponytd »</TD></TR><TR><TD CLASS="quote">
the lobe size's are bigger and lift and duration are different for starters</TD></TR></TABLE>
I was being sarcastic.
Are you simply wanting to know maximum lift before piston to valve interference?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HYBRIDSIRACCORD »</TD></TR><TR><TD CLASS="quote">Remember, Biggest isnt always the Best!</TD></TR></TABLE>
Damn Bro your girl is lyin to you..lol JK.
Dont get the biggest and baddest cam you can get. Get a cam that suits your setup.
all motor b20b
22
Sep 29, 2003 01:01 PM
