Compression and leak down tests
i did my comp test in about 15 minutes. i havent done a leakdown and dont know what all is entailed.
1 - get compression tester from autozone for about $20
2 - remove all spark plugs
3 - lightly coat the threads of the comp tester with anti sieze
4 - screw comp tester into #1 cyl
5 - crank engine over 5 times
6 - take reading.
7 - repeat 3 times each cylinder then redo #1 (or which ever you first )
6 - take reading.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shakes »</TD></TR><TR><TD CLASS="quote">i did my comp test in about 15 minutes. i havent done a leakdown and dont know what all is entailed.
6 - take reading.
7 - repeat 3 times each cylinder then redo #1 (or which ever you first )</TD></TR></TABLE>
Correct me if i'm wrong, but shouldn't you also push
the pedal to the metal "
", while cranking it as well?
Also i think if you pull the fuel pump relay,
it won't dump fuel in the cylinders while your testing it.
6 - take reading.
", while cranking it as well?Also i think if you pull the fuel pump relay,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR »</TD></TR><TR><TD CLASS="quote">
if you pull the fuel pump relay why would you put the pedal to the metal?
i did neither. i just cranked it 5 times and read the gauge.
i did neither. i just cranked it 5 times and read the gauge. </TD></TR></TABLE>
When I did mine a while back, i did it the same way as you.
But I know some people do it the other way ( at wot with the fuse pulled )
I can see what the helms says tomorrow on it
i didnt even think to consult the HELM. i just called BEN.
BTW, lovin that speed racer avatar!
</TD></TR></TABLE>i didnt even think to consult the HELM. i just called BEN.
You should have the throttle wide open when doing the compression test., Other then that follow Doug's instructions.
A leakdown tester is like 70.00 - 100.00, IIRC. Basically you need to put the piston at TDC and you fill the cyl with compressed air. Then you monitor pressure loss via the tester
