inline four remapped ecu
I have an inline four pr3 ecu that they remapped for me. I was wondering if anybody has had any experience with thier ecu's. so far this thing is garbage everytime I put it in reverse I get a code 73 (random misfire cyl 3). I have replaced all the ignition components ie spark plugs, wires, cap, rotor ect. I have also gone as far as hooking up my friends ZDYNE and the car runs fine no check engine lights or anything. I guess my big concern is if anybody has got any shotty products from them before. any answers would be appreciated.
I have e-mailed thier tech address as they said to do and they have not e-mailed me back. just waiting for thier response on the issue. I was just wondering what everyones experience is with IL4 and thier quality on products. thanks for the response anyways.
Have you modded your HF harness????
See: https://honda-tech.com/zerothread?id=982646
Might not be your problem, but the HF only stuff can screw with you after a swap. One of those "HF only" things is a reverse switch!
HTH
chris
HTH
chris
have you tried that?
