wire up a relay for a fog lights
Old Sep 14, 2004 | 05:22 PM
4DRmafia's Avatar
Default wire up a relay for a fog lights
i was told to wire up a relay for my fog light and i do need to since my switch keeps gettin hot so if any 1 has a diagram on how to wire up a relay and explain it to me will be great
thanks
Ron
Old Sep 14, 2004 | 05:54 PM
Eric R's Avatar
Default Re: wire up a relay for a fog lights (SkipMic2006)
30 Amps relay:
+87 __
85 l __ l 86 +
+30 l
87 goes to (+) of Battery fusing a 14ga. wire at the bat.
86 can go directly to 87.
85 goes to a grounded (-) switch on the dasboard.
30 is the 12V (+) output to the (+) side of the fog lights.
You can ground the lights to chasis near the brackets.
Good luck!
Old Sep 14, 2004 | 06:47 PM
4DRmafia's Avatar
so is that a 4 pong relay ? can i use a relay from a radiator fan and wire it up ?
Old Sep 14, 2004 | 07:45 PM
fcm's Avatar
fcm
Old Fart
Default Re: (SkipMic2006)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkipMic2006 &raquo;</TD></TR><TR><TD CLASS="quote">so is that a 4 pong relay ? can i use a relay from a radiator fan and wire it up ?</TD></TR></TABLE>link http://www.the12volt.com then klick on relays under basics. 94
the_dxB16
Oct 17, 2008 08:06 AM
hamorhead
Lighting
Sep 19, 2008 05:45 AM
B18EG6
Jul 27, 2004 05:02 AM
B18EG6
Audio / Security / Video
Jul 26, 2004 03:47 PM
caliriptide
Mar 11, 2004 06:25 PM
