oil burning question
Old Sep 14, 2004 | 03:27 PM
2k1 SSM GSR's Avatar
Default oil burning question
my car was 2.5 quarts low on oil today. did a compression test, it came out fine. couldn't find any leaks anywhere.
the only thing i can find as a problem is my oil dipstick housing comes out if you pull on it, it's not securely fastened down. that's the only near leak issue i could find.
do you think my car could burn 2.5 quarts do to that or what?
Old Sep 14, 2004 | 03:33 PM
96_GsR_BlownEngine's Avatar
Default Re: oil burning question (2k1 SSM GSR)
It might have leaked out that much....ever have any oil consumption (burning) problems before? You should consider replacing your dipstick holder or getting yours in tightly.... A new holder is around $10 from honda and is easy to install - especially if you can get your old one out easily.
Old Sep 14, 2004 | 03:38 PM
hott-nix's Avatar
my car is eating oil pretty badly also.
i was down about half a liter this past weekend
just keep it topped up between changes and you should be fine
Old Sep 14, 2004 | 04:10 PM
Default Re: oil burning question (hott-nix)
kinda sucks cause when i got to check my oil, the holder and all comes out with it.
Old Sep 14, 2004 | 04:18 PM
gsrboi80's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k1 SSM GSR &raquo;</TD></TR><TR><TD CLASS="quote">kinda sucks cause when i got to check my oil, the holder and all comes out with it.</TD></TR></TABLE>That might be part of ur problem
Old Sep 14, 2004 | 06:36 PM
dc2_tuner's Avatar
Default Re: oil burning question (gsrboi80)
MY CAR WAS DOING THE SAME THING SO I CALLED THE ACURA DEALERSHIP AND ASKED THEM WHAT WAS THE PROBLEM AND THEY SAID IT IS NORMAL FOR THE BSERIES VTEC MOTORS TO "LOSE" 1 QUART EVERY THREE THOUSAND MILES!!!
Old Sep 15, 2004 | 01:17 AM
jdmkrazie's Avatar
Default Re: oil burning question (dc2_tuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2_tuner &raquo;</TD></TR><TR><TD CLASS="quote">MY CAR WAS DOING THE SAME THING SO I CALLED THE ACURA DEALERSHIP AND ASKED THEM WHAT WAS THE PROBLEM AND THEY SAID IT IS NORMAL FOR THE BSERIES VTEC MOTORS TO "LOSE" 1 QUART EVERY THREE THOUSAND MILES!!!</TD></TR></TABLE>
yeah but he isn't losing just 1 quart. he lost 2.5 lol.
just try fixing the dip stick holder problem. then see what happens.
and does anyone else notice that vtec does tend to burn oil?
Old Sep 15, 2004 | 09:57 PM
dc2_tuner's Avatar
Default Re: oil burning question (jdmkrazie)
Old Sep 15, 2004 | 10:11 PM
thaiphob's Avatar
Nikon!!!
no need for the caps dood.
the dipstick hold comming out when you pull it is gonna be the cause of your issues.
Old Sep 15, 2004 | 10:23 PM
Sack Master's Avatar
Default Re: oil burning question (thaiphob)
Neither of my motors lost any oil between changes. And it is never black either. I check my oil everytime I get gas just to be safe. If I run it hard maybe 1/4 quart. Then again I don't use the good oil like everyone else does .
Old Sep 15, 2004 | 10:39 PM
GrayT's Avatar
Tell me you asked why...
Old Sep 16, 2004 | 06:01 PM
gsrboi80's Avatar
Default Re: oil burning question (GrayT)
yea no oil burn here either (knock on wood)
motegicivic
11
Jan 17, 2012 08:14 PM
210jdmgsr
Aug 15, 2007 03:55 PM
BoBo Racing
Aug 12, 2003 10:35 AM
94thundergrey
Feb 2, 2003 10:22 PM
GsrSdn
Sep 22, 2002 01:10 PM
