GSR axles work in CRX Si w/B16?
I have the Y-1 tranny. I need new axles... I know a guy that's got a set of GSR axles... Will it work?
On a related note, will any suspension swap over from a '00 GSR? Brakes? I got some info in the searches, but it was sorta vague etc... If any of the above actually work, I'll do a write up to help clarify things for the future...
Thanks ya'll
Thanks ya'll
im pretty sure all b-series axles will work, but i do know some fit better than others. a friend of mine used gsr axels in his 90 integra ls, and im using 90 integra ls axles on my b16/crx. about the suspension, thats something i would look into.
U can leave the ABS ring on, I dont think it matters. What does matter is what halfshaft you are running. If you are using a 90-93 integra HS, then u need 90-93 axles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrspeaker »</TD></TR><TR><TD CLASS="quote">90-93 integra axles fit....</TD></TR></TABLE>
Dam this jubject has been covered thousandths of time, with the same question, What axels for b16, What axels should I use on a B16motor
There is a Search botton use it. S-E-A-R-C-H
all ways a good idea
It's been covered a lot. That's true, but which threads/ statements are right? Most of the threads mention the 90-93 axles, but don't say whether or not GSR axles will work. Does that mean that they absolutely don't work, or does it mean that people haven't tried it yet?
Also, will the sus. work? I searched that too... I'd love if you/someone could help me find the pertinant info in all of the threads that will help me out.
I tried using the "Knowledgebase", but there isn't anything listed under "B16 CRX swap"... That's why I figured I could contribute a writeup, but I would like to know if anyone knows whether it'll work or not.
Thanks for your contribution...
as long as u use a 94-up midshaft you can use gsr axles.
they are totally diferent from the 90-91 integra axles and jdm b16a1 axles.
take a look at the inner joints , they wont match up if you were tryin to use gsr axles after using 90-93 axles
215 posts and the last two treads that I've read had you saying search.
How 'bout you contribute information of value or shut up?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16 CRX »</TD></TR><TR><TD CLASS="quote">
all ways a good idea</TD></TR></TABLE>
Mike P.
Aug 21, 2003 01:25 PM
