would like a new motor for si
Old Sep 14, 2004 | 02:52 PM
SI HB's Avatar
Default would like a new motor for si
looking at B16 but what about vtech the si comes with will i lose that or what , do i have to change the motor mounts , headers too or should i keep what I have and rebuild a little beast with a turbo. Im lost I been stuck with a 1.5 four door civ for a long time now. but now the si is in the house, i need some affordable help. you guys know which way im headed SPEED but i need the basics HELP ME OUT break it down for a bro
Old Sep 14, 2004 | 04:25 PM
reactiondc2's Avatar
Default Re: would like a new motor for si (SEDAN PUSHER)
what year of an si do you have?and no you will not be giving up VTEC if you go b16
Old Sep 14, 2004 | 05:43 PM
SI HB's Avatar
Default Re: would like a new motor for si (reactiondc2)
90 good ? i wasnt thinking
Old Sep 14, 2004 | 05:52 PM
T.J.'s Avatar
you wil have wiring to do but if you buy a vtec motor than no you wont loose it you will have to just wire the vtec up
Old Sep 14, 2004 | 05:54 PM
SI HB's Avatar
Default Re: would like a new motor for si (T.J.)
ok so i can keep the same tranny too
Old Sep 14, 2004 | 06:00 PM
Tbone's Avatar
You can now use cable or hydro trannies depending on which mount kit you use.
Old Sep 14, 2004 | 06:08 PM
SI HB's Avatar
so know stock mounts not even from other honda and what tranny would come with b16 im sorry if i have dum ? but i just need to really understand everthing befor i start this swap ty
Old Sep 14, 2004 | 06:23 PM
T.J.'s Avatar
Default Re: (SEDAN PUSHER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SEDAN PUSHER &raquo;</TD></TR><TR><TD CLASS="quote">so know stock mounts not even from other honda and what tranny would come with b16 im sorry if i have dum ? but i just need to really understand everthing befor i start this swap ty</TD></TR></TABLE>
If you do decide to put a b series motor in your crx you will need knew mounts. If you do go with a b series motor you need to make sure you get one with a cable tranny. Now haspot does make a kit to convet cable to hydro. I also suggest converting from obdo to obd1.
rdawg000
Dec 6, 2004 05:26 PM
ImportPower13
13
Sep 26, 2004 04:50 PM
typesguy
Jan 29, 2004 06:53 AM
dsmith817
Feb 26, 2003 08:05 PM
dropd4door
17
Dec 16, 2002 08:26 PM
