Anyone running rocket motorsports cams i have a problem with mine!!!!
Old Sep 14, 2004 | 02:13 PM
hatchbackhonda's Avatar
Default Anyone running rocket motorsports cams i have a problem with mine!!!!
PROBLEM FIXED i actually didnt put these cams in i got the car with them in and the kid oviously didnt really know what he was doin he said that the timing had to be really advanced for it to idle(which was wrong) i set timing on the distributor to stock and it runs 100% better!!!!! it even holds idle at 800 fluxates at lil between 7-9 but mainly 800rpms
i am running the m23 and i cant get them to idle for nothing
the distributor is turned all the advanced just to get the car to idle (this doesnt seem right)!!!!
i am running rockets valvesprings and retainers
spoon headgasket
arp head studs on a jdm itr motor
and the cam gears are set at zero
Modified by hatchbackhonda at 6:06 AM 9/15/2004
Old Sep 14, 2004 | 02:27 PM
civicsitek GanGsTa's Avatar
Default Re: Anyone running rocket motorsports cams i have a problem with mine!!!! (hatchbackhonda)
PM Rocket about it. Your cam timing may be off.
Old Sep 14, 2004 | 03:27 PM
743power's Avatar
Default Re: Anyone running rocket motorsports cams i have a problem with mine!!!! (civicsitek GanGsTa)
check cam gear timing, ignition timing, fuel pressure.
what management are you using?
Old Sep 14, 2004 | 03:52 PM
v4lu3s's Avatar
RTFM
last guy i talked to about rocket cams had to adjust cam gears by nearly 5 degrees to get timing right.
Old Sep 14, 2004 | 04:18 PM
help
Old Sep 14, 2004 | 04:23 PM
did you read what people just said?!
Old Sep 14, 2004 | 04:32 PM
i did read what they said and that gave me somewhere to start!!!!! i dont know where is a good place to start to set the cams
Old Sep 14, 2004 | 04:34 PM
chad's Avatar
Moderator
it's funny...people think you can just drop cams in and make mad power.....lol.....
Old Sep 14, 2004 | 04:39 PM
Default Re: Anyone running rocket motorsports cams i have a problem with mine!!!! (chad)
yea i really dont think that way bud i am just trying to get my car to idle better and get it somewhat dialed in so it can go to my tuner and have my hondata put on and tuned
Old Sep 14, 2004 | 05:42 PM
Archidictus's Avatar
Unceasing Measure
Most of Rocket's stuff isn't designed for street use, regardless of what they say on the site.
Old Sep 15, 2004 | 06:26 AM
bunnyrabbit's Avatar
what you want to do is set the timing to about 8 degrees retarded--- you should have a perfect idle then--- i actually set mine to 10 degrees retarded and they ran great--- LOL
iheartmyctr
Sep 16, 2008 04:32 PM
90crxsib16
Jan 12, 2005 03:15 PM
LSVTEC 91 Civic
Aug 31, 2004 06:35 PM
