changing trans oil
Hi i was about to change the tranny oil on my H22A1 prelude and there are two bolts , one 3/8 drive ratchet fits into and under that is one a 1/2 inch drive fits into. Is the 1/2 inch one the drain and the other to fill ?
You're both wrong. dcr, you aren't looking at the right bolts. The ones you need are more towards the middle of the car next to where the passenger side alxe fits into the tranny, not on the very end of the tranny like the ones you are thinking of. The drain bolt is the one on the bottom, and it's a 3/8 ratchet bolt I believe. The fill bolt is a normal bolt (don't remember what size) and it's in the 9 o'clock position relative to the drain bolt.
The drain bolt is at the bottom of the pic, the bolt is removed. The fill bolt is in the upper left hand corner of the pic.
Excuse my dirty tranny, I had a torn CV axle boot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Behan »</TD></TR><TR><TD CLASS="quote"> [img]
I bet that wasn't the first time either.
</TD></TR></TABLE>I bet that wasn't the first time either.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sticky Tires »</TD></TR><TR><TD CLASS="quote">
Actually you're right, I found the bad axle/torn boot and replaced it with a remanufactured axle. Well the remanufactured axle had a slit in the boot and i didn't notice till 2days after i installed it.
So thats actually two loads of CV axle greaser under there.
I cleaned it all up when i changed the clutch
</TD></TR></TABLE>Actually you're right, I found the bad axle/torn boot and replaced it with a remanufactured axle. Well the remanufactured axle had a slit in the boot and i didn't notice till 2days after i installed it.
ah, the joy of owning a honda. i had the same problem, 2 slits in less than a year.
</TD></TR></TABLE>ah, the joy of owning a honda. i had the same problem, 2 slits in less than a year.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sticky Tires »</TD></TR><TR><TD CLASS="quote">No, I think you fill in the same hole you drain. Someone correct me if i'm wrong. </TD></TR></TABLE>
How would you fill in the same hole you drain? I would pay good $$$ to see you try that... lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kellyk75 »</TD></TR><TR><TD CLASS="quote">
How would you fill in the same hole you drain? I would pay good $$$ to see you try that... lol</TD></TR></TABLE>
argh i admitted i was wrong.
all you gotta do is flip the car on it's side and refill using the same hole, duh.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raylude »</TD></TR><TR><TD CLASS="quote">is there a seprate place to fill the differential?</TD></TR></TABLE>
what do you mean?
there are alternate places to put in tranny oil. Tranny vent pipe is one, VSS sensor hole is another. A little less messy than using the fill hole.
what do you mean?
doom26464
Jun 18, 2008 07:10 PM
asubennett
Aug 21, 2003 05:14 PM
RCautoworks
Feb 16, 2003 11:16 PM
