4th gen H22 Accord times
After a heated discussion this morning, i decided to try and gather some info. Im sure someone on here knows first hand. What does a 4th gen accord with an h22 swap approx. run? 1/8th and 1/4 times and mph's would be good. Im going to say its got some weight reduction as well. Lets say, around 2700lbs. Otherwise, stock h22. I've seen several hatches with h22 swaps running mid 8's or better around here. So whats the scoop?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboCustomz »</TD></TR><TR><TD CLASS="quote">After a heated discussion this morning, i decided to try and gather some info. Im sure someone on here knows first hand. What does a 4th gen accord with an h22 swap approx. run? 1/8th and 1/4 times and mph's would be good. Im going to say its got some weight reduction as well. Lets say, around 2700lbs. Otherwise, stock h22. I've seen several hatches with h22 swaps running mid 8's or better around here. So whats the scoop? </TD></TR></TABLE>
you're right!!! many people here do know, but they won't tell u....u'll have to find it yourself....(hint: https://honda-tech.com/zerosearch )
H22 Accords run anywhere between about 14.6-15.2 on stock H22 and stock car. Average Speed is about 90mph I guess.
I suck at driving so my best time was 15.1 on a stock motor.
8 Sec. H22/Civics is insanly fast....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n-line4 »</TD></TR><TR><TD CLASS="quote">8 Sec. H22/Civics is insanly fast....</TD></TR></TABLE>
I think he mean 8 second 1/8 (still fast
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .50 Cal Cow »</TD></TR><TR><TD CLASS="quote">sorry to hijack. but speaking of what's the status of the H22 swap on the accord VRDrvr? think last I read you were going to boost it to?</TD></TR></TABLE>
correct, expect a thread in kills shortly
i got a h23 non-vtec swap in my 92 lx 4 door. i did a 16.016 @87mph. i had bald tires plus my car was really slammed and i have no camber kit
i plan on converting it to vtec soon. i should do 14's no problem after that
Thats about what I expected. I bought a JDM H22 from a guy I know after his car got totalled out and was weighing my options as far as what to put it in. Its the first honda i have messed with. I just wanted something a little different. I figure i can get a 4 door down to around 2600lbs without to much of a problem. That and a little boost and I should be happy.
