best cam gear on market? lightest?
Old Sep 14, 2004 | 09:37 AM
sol2nr's Avatar
Default best cam gear on market? lightest?
which cam gear would everyone say is the 'best' on the market?
the Venom Fang gears claim to be the lightest, would they not be the best b/c of it? Anyone use them w/out issues. They only have 4 bolts compared to others like the new AEMs which have 5 bolts.
Anyone have anything against the AEM cam gears, because i'm going to do a dealership by in with AEM and i'll just take them for my engine. As long as there isn't any major problem w/ them. However, i'd like the gears to be as light as possible.
thanks.
i searched and couldn't find much.
Old Sep 14, 2004 | 11:36 AM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: best cam gear on market? lightest? (sol2nr)
new aems
Old Sep 14, 2004 | 07:50 PM
sol2nr's Avatar
Default Re: best cam gear on market? lightest? (HOOKUPS)
anone else have an opinion. just how much lighter can the Venom's be?
any downside to going w/ the Venoms?
Old Sep 14, 2004 | 09:35 PM
92bubblesi's Avatar
The new AEMS have more than three bolts. I will have to check into those.
Old Sep 14, 2004 | 09:45 PM
Propulsion's Avatar
Default Re: best cam gear on market? lightest? (92bubblesi)
get the ST corsa, special locking mechanism to eliminate chances of slipping
Old Sep 14, 2004 | 09:58 PM
racingfan's Avatar
always skunk2
Old Sep 14, 2004 | 10:33 PM
rev-speed's Avatar
str has nice line markings on them.
Old Sep 15, 2004 | 03:08 AM
MenaceL.A.671's Avatar
the new AEM are sweeet.... 5 bolts and they hella light ... lighter than the 3 bolts AEM....
Old Sep 15, 2004 | 08:26 AM
Propulsion's Avatar
Default Re: best cam gear on market? lightest? (m2slsvtec)
why do they put more bolts on? Because they used to slip.
Whats the best way to guard agains slippage? lock bolt design...period.
Old Sep 15, 2004 | 04:47 PM
sol2nr's Avatar
Default Re: best cam gear on market? lightest? (SilverCIVIC96)
i think i'll stick w/ the new AEMs, their 3 bolt design has worked on many cars in the past.
Old Sep 15, 2004 | 04:56 PM
sporkcrx's Avatar
I have a JG, it's the shiznit
Old Sep 15, 2004 | 06:28 PM
Propulsion's Avatar
Default Re: best cam gear on market? lightest? (sporkcrx)
I have heard on more than one instance the AEM 3-bolt one slip, causing valve damage. Hell, my best friend's LS had this happen, good thing the motor was stock and no damage was done.
Old Sep 15, 2004 | 06:40 PM
KillaB-'s Avatar
i got the oldschool JG LIghtspeed, they have untold track time mileage, nos abuse and still dont slip.
Old Sep 15, 2004 | 07:25 PM
DYNO-PRO
Default Re: best cam gear on market? lightest? (KillaB-)
JG's are hard as fuc to read (hell for a tuner)
Old Sep 15, 2004 | 07:50 PM
archmage's Avatar
Default Re:
Maybe consider the material it is machined from too.
Skunk2 and Toda = 7075 aluminum (NICE)
Most others = 6061 aluminum (cheaper quality).
I suppose you could also consider bolt design, readability, weight, blah.
Edit: Seems to me that Skunk2 has 6 bolts and 7075 aluminum... still under $250, not bad.
Modified by archmage at 10:48 AM 9/16/2004
Old Sep 15, 2004 | 09:03 PM
PrettyLude's Avatar
toda racing gears
Old Sep 15, 2004 | 10:01 PM
integrasi's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">toda racing gears</TD></TR></TABLE> or spoon which ever you can get it cheaper
Old Sep 16, 2004 | 09:27 PM
sol2nr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverCIVIC96 &raquo;</TD></TR><TR><TD CLASS="quote">I have heard on more than one instance the AEM 3-bolt one slip, causing valve damage. Hell, my best friend's LS had this happen, good thing the motor was stock and no damage was done. </TD></TR></TABLE>
my previous quote was stating that I am considering the new 5 bolt design, over the old 3-bolt.
still a good heads up though.
Old Sep 18, 2004 | 09:53 AM
crexer's Avatar
nobody has mentioned anything about STR cam gears.....they have either 5 or 6 bolts and they are like 175 for the pair on ebay. What kinda aluminum are they made of? I dont think im gonna trust anything made my junk2 anymore after hearing all the negatives about their stuff breaking
Old Sep 18, 2004 | 10:10 AM
PHiZ's Avatar
Default Re: best cam gear on market? lightest? (crexer)
Would you neccesarily want the lightest, or the closest to factory weight?
-PHiZ
Old Sep 18, 2004 | 11:06 AM
-faded-'s Avatar
Default Re: best cam gear on market? lightest? (PHiZ)
juns are good. use part of the oem gear so they fit and work perfect
Old Sep 18, 2004 | 11:09 AM
crexer's Avatar
Default Re: best cam gear on market? lightest? (hybridlsR)
i wanna know about the weight of them too as PhIz was asking. Do you want the lightest gears?
AFAccord
Jul 14, 2008 01:44 PM
Hardedge
Nov 9, 2007 07:22 PM
DualCamDan
Feb 24, 2004 03:30 PM
90TegRex
Jan 2, 2003 10:43 AM
acatak
Jul 15, 2002 05:41 PM
