11.5 to 1 compression question
Old Sep 14, 2004 | 08:43 AM
cjohnson_2's Avatar
Default 11.5 to 1 compression question
Im going to be running 11.5 to 1 compression in my b18c1. My question is will that be too much for some skunk2 stage 1 cams? Will the static compression be to high?
Old Sep 14, 2004 | 09:14 AM
DefiantGSR's Avatar
Default Re: 11.5 to 1 compression question (cjohnson_2)
~ 11.5:1 is perfect.
Old Sep 14, 2004 | 10:32 AM
Big Teggie's Avatar
Thats a good C/R for those cams in a street motor.
Old Sep 14, 2004 | 10:48 AM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: 11.5 to 1 compression question (Big Teggie)
yes that comp ratio is good if you have a decently flowing head you will be using 85% of the cams potential
Old Sep 14, 2004 | 11:01 AM
SkRiBLaH's Avatar
Default Re: 11.5 to 1 compression question (HOOKUPS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOOKUPS &raquo;</TD></TR><TR><TD CLASS="quote">yes that comp ratio is good if you have a decently flowing head you will be using 85% of the cams potential </TD></TR></TABLE>
approximately 85.0% huh
kidding
Old Sep 14, 2004 | 02:49 PM
DYNO-PRO
Default Re: 11.5 to 1 compression question (SkRiBLaH)
yes 85% of the max lift/duration compared to a 1.8-2.0 ltr engine with a volumetric eficiency of 100 basically the less air you can move through an engine the smaller cam profile you will need
VTIargentina
27
Jun 9, 2010 06:03 AM
jimbrown
Jul 5, 2007 12:11 AM
The Destroyer
12
May 30, 2006 02:57 PM
jdmcx
Dec 21, 2003 06:34 AM
Notaverage
Dec 1, 2003 04:53 PM
