Suspension bushing question
what is number 6 on this diagram, and is it hard to replace?
a noise is comming from under my car, and when i popped off the tire, the bushing was totally gone.
Majestic Honda
Majestic Honda
#6 is the bushing for the endlink for the swaybar. Very easy to replace. One you pop the bolt off, and push the swaybar up the bushings practically fall on its own.
Just a tip, it is usually #2 that squeeks. #6 wouldn't really squeek much. Pull the bushing out (easy), lube it with silicone paste and see if it helps. I did mine in 20 min including jacking up the car.
thanks, i'm pretty sure its the bushing though, considering its not even on the car anymore.
but that sway bar isn't under any high tension is it?
98civdx
Suspension & Brakes
17
Mar 12, 2011 04:27 PM
g2b2
May 2, 2007 10:37 AM
