MoTeC users...
I have a few questions...
When installing a MoTeC M4 ecu, how did you retain the use of the alternator and starter. I haven't had time to work this out yet so any info would help.
Modified by 01-0041 at 8:18 AM 9/14/2004
the starter is the easy one the lead that comes from the starter goes right back to the keyswitch so all you have to do is figure out which wire off the key sw iforget which one it is and run a new wire in your motec harness to the straer from the key sw, the altis also easy if you dont care about teh idiot light gauge in the dash just wire it straight to the battery and be done with it.
CLE
22
Apr 5, 2006 09:27 AM
tur3oDC4
Sep 17, 2005 09:41 AM
