Type-R head on a B16
Old Sep 14, 2004 | 06:14 AM
J-Spec EG's Avatar
Default Type-R head on a B16
Just wondering if anyone has a b16 with a ITR head mated with it. Im looking at getting a b16 complete block minus pistons for 400 with a Jun Clutch and flywheel from a freind and i would like to get a typer head would it be a noticable difference do you think or would i be better off with a stock b16 head. Keep in mind im going to sit the motor over the winter and built it so im talking about a bare head with all new valvetrain and cams and such things as that. Let me hear some opinions.
Old Sep 14, 2004 | 06:17 AM
GAccord's Avatar
Default Re: Type-R head on a B16 (J-Spec EG)
jdmfreestyle (sp?) has that setup.
Old Sep 14, 2004 | 06:20 AM
rodrez.'s Avatar
You won't see a major difference between the 2 heads. Very mild port work, better valvesprings/retainers. If you're planning to work on the head anyway, and you can find a cheaper B16 head, might want to look toward that. The cams and intake manifold are the biggest differences, but it sounds like you'll be upgrading those anyway.
Old Sep 14, 2004 | 06:24 AM
J-Spec EG's Avatar
thats exatly right i have a s2 mani and a machine shop at my disposal so maybe just a b16 head?
Old Sep 14, 2004 | 06:37 AM
rodrez.'s Avatar
Default Re: (J-Spec EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J-Spec EG &raquo;</TD></TR><TR><TD CLASS="quote">thats exatly right i have a s2 mani and a machine shop at my disposal so maybe just a b16 head?</TD></TR></TABLE>
Personally, if it was cheaper, I'd go with the B16, knowing that I was going to change the things that make the R head more expensive anyway.
Old Sep 14, 2004 | 10:26 AM
J-Spec EG's Avatar
Default Re: (rodrez)
word up rodrez thanks for the help
Old Sep 14, 2004 | 10:54 AM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
agreed depending on what you are going to pay for the ITR head compared to the b16 head you amy be able to swoop up the b16 head and get some decent port werk done to it
Old Sep 14, 2004 | 01:11 PM
B-B-K's Avatar
Default Re: (HOOKUPS)
From my understanding, the Type R head and B16 heads are the same cast. The ITR head has better springs, cams (obviously), and I beleive a mild port job. But the acctual head itself is the same.
Not to sure on the going rate for an ITR head, but it might be cheaper just to get a B16 head and do the internal work.
Just my 2 cents.
Matt
Old Sep 14, 2004 | 03:14 PM
eLUDEnu
Guest
Posts: n/a
Default Re: (B-B-K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B-B-K &raquo;</TD></TR><TR><TD CLASS="quote">From my understanding, the Type R head and B16 heads are the same cast. The ITR head has better springs, cams (obviously), and I beleive a mild port job. But the acctual head itself is the same.
Just my 2 cents.
Matt</TD></TR></TABLE>
same here
Old Sep 14, 2004 | 03:19 PM
StorminMatt's Avatar
Default Re: (eLUDEnu)
It really all boils down to how cheap you can get the ITR head.
Old Sep 14, 2004 | 03:23 PM
infamousR13's Avatar
Default Re: (StorminMatt)
The itr head does not in any way have a port job from the factory. This is a rumor/myth that I have heard many times, but it is not true.
Old Sep 15, 2004 | 01:28 AM
J-Spec EG's Avatar
Im suprised that all of us have never heard that, thats strange. But thanks guesss u learn something new every day.
Old Sep 15, 2004 | 03:03 AM
Default Re: (infamousR13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infamousR13 &raquo;</TD></TR><TR><TD CLASS="quote">The itr head does not in any way have a port job from the factory. This is a rumor/myth that I have heard many times, but it is not true.</TD></TR></TABLE>
I guess it all depends on what you consider a 'port job' to be. As I understand it, the B18C5 head has simply been cleaned up a little around the valve seats to make for a smoother transition between the seats and the head casting itself. This is certainly not much. And I can understand how some people may not consider this to be a 'port job'. But it is something. And it does help somewhat.
Old Sep 15, 2004 | 04:32 AM
1 2 NV's Avatar
exactly what matt said, i have both a B16 and a ITR head. the clean up is mild, its just a slight blending of the bowls right above the valve
Old Sep 15, 2004 | 06:48 AM
J-Spec EG's Avatar
Default Re: (1 2 NV)
i think im going to sell the b16 block and get a b18c1 block and then get a gsr head and call it a day. I appreciate all the help.
jayswizz
Oct 7, 2015 06:34 AM
92b16si
Nov 18, 2004 05:13 PM
South sol
Feb 3, 2004 03:19 PM
