oil light stays on????
Old Sep 14, 2004 | 01:03 AM
W.O.P.'s Avatar
Default oil light stays on????
my oil light stays on for no apparent reason. my oil is always full. could it be the oil sensor? this happened a little bit agao when i had my guage cluster apart. could i have messed up a wire in there? i just took out the bulb and called it a day. but on a opposite note. my gas light never comes on. i changed the bulb in that with no success. whats wrong with my F*ckin car????
Old Sep 14, 2004 | 09:20 AM
W.O.P.'s Avatar
Default Re: oil light stays on???? (1quickLS)
holy ****, anyone?
Old Sep 14, 2004 | 09:44 AM
psychotic_z's Avatar
If the oil light came on and stayed on *directly* after you dicked with your cluster, whip out that multimeter and check out the cluster with a fine toothed comb, so to say.
If it came on a few days or weeks after you dicked with the cluster, then that's less likely to be the problem. If that's the case, start checking wiring and finally the oil sensor next to your oil filter. Look in a Helms manual to troubleshoot those.
Seeing how your gas light won't come on either (you know you have to be on or below E for that sucker to come on), I bet you crossed a wire, grounded something you shouldn't have, or peed on the back of your cluster. My money's on the first two.
Old Sep 14, 2004 | 10:52 AM
Wimpy.'s Avatar
Default Re: oil light stays on???? (psychotic_z)
just press the reset button under ur steering wheel
Old Sep 14, 2004 | 11:38 AM
W.O.P.'s Avatar
Default Re: oil light stays on???? (Gentlemangsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gentlemangsr &raquo;</TD></TR><TR><TD CLASS="quote">just press the reset button under ur steering wheel </TD></TR></TABLE>thats for the maint. light bro. the gas light never worked... i dont know what that problem is
r_honda
Mar 31, 2016 07:12 PM
GSR_slut
Sep 1, 2010 08:55 AM
bradennicely
Mar 29, 2010 09:42 AM
crazyguy
Sep 5, 2007 04:52 PM
idratherbike
Feb 19, 2007 10:07 PM
