gas gauge on cluster not working?
the gas gauge on my cluster is not working. the arrow just stays in place where it was left. I filled up the gas tank and the arrow still does not move. I also replace the gas section of the cluster with one from another cluster, but no luck. anyone know the problem or know how i could fix this? thanks.
try to check the wiring to the tank sensor.. not sure if theres a fuse that works on some of the cluster, but might wanna check that. and did you try to hook up another cluster to ur car and see if that works?
did you change to another cluster? liek from a 94-97 to a 98-01 and via versa? if so u need to change the green sheet on the back
MTarry
11
Jan 15, 2013 06:46 PM
