Coolant drains quickly
Old Sep 13, 2004 | 07:49 PM
hyperazn108's Avatar
Default Coolant drains quickly
Simple as that. a full bottle gone in 1 day. i refill every day. WTF. dont see any leaks.
Old Sep 13, 2004 | 08:12 PM
Padronis's Avatar
Default Re: Coolant drains quickly (hyperazn108)
Either you have a small leak that only leaks under pressure, or you are burning it. Let your car wrm up and watch for leaks anywhere as it idles.
Old Sep 13, 2004 | 08:34 PM
Accord2NR's Avatar
is your temp gauges going to hot as well? if so you might need a new thermostat, it actually can be a lot of things, wen i had my RS it did that but then i had to change my radiator caps, could be a lot of things....
Old Sep 13, 2004 | 09:07 PM
Two_K Si's Avatar
Default Re: Coolant drains quickly (AcuraINTEGRAGSR)
You might want to also take a look at your waterpump.
Old Sep 13, 2004 | 09:46 PM
jaydeemmmm's Avatar
I'm experiencing the same problem right now. 3 things I'm pointing at. 1. Thermostat 2. Radiator Cap 3. The Radiator itself.
After driving on the freeway for about 10 minutes today, my car's temp started heading toward the H. I quickly got off the freeway and stopped at a parking lot of a mall. I saw smoke coming from underneath the right side of my hood. I lifted up the hood and saw that coolant had sprayed everywhere and my coolant inside the bottle was boiling. You can actually hear and see the coolant boiling. Any of you have had this kind of experience?
Old Sep 13, 2004 | 10:10 PM
Default Re: (jaydeemmmm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydeemmmm &raquo;</TD></TR><TR><TD CLASS="quote">I'm experiencing the same problem right now. 3 things I'm pointing at. 1. Thermostat 2. Radiator Cap 3. The Radiator itself.
After driving on the freeway for about 10 minutes today, my car's temp started heading toward the H. I quickly got off the freeway and stopped at a parking lot of a mall. I saw smoke coming from underneath the right side of my hood. I lifted up the hood and saw that coolant had sprayed everywhere and my coolant inside the bottle was boiling. You can actually hear and see the coolant boiling. Any of you have had this kind of experience?</TD></TR></TABLE>
for your problem your coolant fan fuse is broken. replace it i believe its a 15
Old Sep 13, 2004 | 10:11 PM
iH8RICERZ's Avatar
Default Re: (hyperazn108)
i've already experienced this...........drive your car, let it sit for a while, and look to see if there is any coolant on your splash guard or on the ground. If this is the case, then you have a cracked radiator which is very common on integras.
KevinEF7
Dec 20, 2017 02:02 PM
stupidasso15
21
Mar 23, 2012 07:19 PM
redGSRguy
Sep 1, 2005 07:12 PM
HUBB
Mar 29, 2004 11:13 AM
92GSR
Jul 29, 2002 08:16 AM
